I have the exact same issue. Also key stuck and will not go into drive unless I press the override. How did you solve this issue? Thank you in advance.Hello, I currently own a 2011 Chevy Cruze LS recently my trunk release stopped working the only way I can release the trunk is by going inside from the back seat and pulling the manual release now all of y tail and brake lights do not work except for the third brake light and the license plate light . the bulbs all look good and common sense tells e very rarely will four bulbs and parking light bulbs will go at once I am concerned because I do not know how much this is going to cost to fix
Hi did you get yours fixed I currently have the exact same issue .I have the exact same issue. Also key stuck and will not go into drive unless I press the override. How did you solve this issue? Thank you in advance.
I have the same issue 2011 Cruze eco any way you got it fixedHello,
I am having the same problem with my 2011 Cruze LS. The tail/brake lights stop working, the trunk will not release, the key gets stuck in the ignition and the car will not come out of park unless i use the override. All just happened at the same time. I changed the brake switch and still have the same problem.
Had to replace my bcm for anyone who sees this threadI have the same issue 2011 Cruze eco any way you got it fixed
Thanks for coming back and posting that. Can you give us any details that the mechanic shared with you?Had to replace my bcm for anyone who sees this thread
Basically said my bcm wasn’t ending a signal to anything and had to be replaced he replaced my bcm and reprogrammed all my computers was a costly but needed fix. Was 1050 to get that doneThanks for coming back and posting that. Can you give us any details that the mechanic shared with you?
Ouch! I asked as it could have been just corrosion on the pins. That is usually something most of us could check and possibly remedy.Basically said my bcm wasn’t ending a signal to anything and had to be replaced he replaced my bcm and reprogrammed all my computers was a costly but needed fix. Was 1050 to get that done
Nope definitely not corrosion I checked for that myself I also used a Maxsys scanner and nothing was getting powerOuch! I asked as it could have been just corrosion on the pins. That is usually something most of us could check and possibly remedy.
