1 - 11 of 11 Posts
Hey guys so I got a baby otw and I can't spend $300 on a tune right now. So my question is...if I upgrade the spring on the bpv or upgrade the bpv all together, would I get more boost without the tune? And if you know any other ways to get more hp/tq there always welcome.
Already got the aftermarket intake.
Run 91/93 octane gas. The LUV engine is designed for 91 octane and throws away power to protect the engine when running on 87 octane. Also, check your spark plugs and ensure they're gapped between 0.028" and 0.030". This seems to be the sweet spot for power from the plugs.
Conservative Acoustic Foam
Also, just because I'm an engineer and can't help myself, your original suggestion is flawed.
The BPV (or BOV, if equipped) does absolutely nothing to regulate boost. The reason you hear about the springs being upgraded is because they can cause a leak if they aren't strong enough to handle higher levels of pressure.
The component of the system that regulates how much exhaust routes through (and around) your turbo is the wastegate. And in our cars the wastegate solenoid is electronically controlled by the ECU. Hence the need for a tune. The computer directly controls the power that the turbo is making.
1 - 11 of 11 Posts
