1 - 13 of 13 Posts
Does anyone know of any guides to replace the turbo charger coolant lines? Mine is leaking and i got the parts i just cant seem to find a good guide!
I’m in the same boat. I started removing my turbo last night. There’s a 17mm bolt that connects one of the water lines to the block that’s a real CU Next Tuesday.
This might help:
@Thebigzeus What size rubber hose did you use to replace the coolant return line? Has it held up over time or was this just done? Mine leaks occasionally, but seems to be a costly repair at the dealership. Any other tips you learned while replacing this part?
Discussion Starter #6
It is expensive up to 1000$☹, when you have the turbo out might as well as do the oil cooler as well
2013 Cruze 1LT
This is the hose I used: Amazon.com: Vibrant Performance 20412 Heater Hose: Automotive (but not at the price they're asking now)
Gotta use those specific clamps too, the ribs on the worm clamps cut into the outside of the hose. It was done about a month ago, no leaks yet, pressure tested for 8 hours.
Discussion Starter #8
I just wrapped up replacing that line. With as big of a pain in the ass it was to remove that turbo, I wish to god I would have replaced everything back there.
Discussion Starter #11
Did you need any special tools for it?
Nothing special. I had to borrow a T45 for the banjo bolt that the attached the oil feed line to the turbo. The oil return tube is a real piss pot to attach without removing the cat. I had to replace that as I destroyed it when I pulled tithe turbo out.
Discussion Starter #13
What kind of clamps did you use with the heater hose? I'm gonna try to find some time to do it, did you drain coolant as well?
1 - 13 of 13 Posts
