1 - 3 of 3 Posts
I have the infamous turbo coolant line leak.
I have the 5/16" ID hose and clamps. I just need to know if I have to drain all the coolant to do this repair.
I suspect I do.
Also, the release mechanism for the one side of the hose clamp is totally in a bad spot where I can't get any tools in there to release the hose. Any ideas on how to get at the release mechanism?
Automotive tire Gas Auto part Automotive wheel system Rim
Gas Auto part Metal Pipe Automotive tire
I suspect I do.
View attachment 295121 View attachment 295122
Try a dremel with a cutting wheel to remove the clamp.
How-To: Replace Turbo Oil Feed Line
One of these is your best friend. It ratchets, locks, and you can come on from almost any angle with it because the heads swivel.
Hair Hand tool Human body Snips Pliers
If it's really tight you can use one of these:
Bicycle handlebar Bicycle part Camera accessory Tool Home appliance
You'll never go back use standard pliers again for clamps.
Either way, you'll drain all the coolant, so you might as well do it beforehand to save a mess.
1 - 3 of 3 Posts
