It's most likely stripped. If you keep spinning it then you will only make it worse. If you drive with it stripped like that then you will have an oil leak or the turbo will not get oil and lead to turbo failure. If you are lucky you could possibly get away with retreading it. But chances are you will need to get a new turbo. Do you think you could send a pic of what the problem is so I can get a better understanding of what I'm looking at so can tell you what you're dealing with and how to fix it? Thanks!
