No that's actually a plastic housing that's pushes down when you insert the line. The picture is my old oil cooler. The new one is definitely pressed in all the way with the gaskets. The hole is just slightly stripped.
I ended up ordering the loctite thread repair kit. It says it can work to 128 ft pounds. It should have no problem handling 89 inch pounds. So simple. If that doesn't work then I'll have to do helicoil and order those angle attachments. But I don't see why it wouldn't work. Thanks for all the info everyone.
