1 - 8 of 8 Posts
It shouldn't be too bad. Just disconnect the intercooler charge tube, the exhaust has one bolt for the v band I think. Then, there are the oil/water lines ( I don't remember if these turbos are water cooled or oil cooled, so there may not be water lines) and then there are some bolts that hold on the heat shield, take those out, then, take out the bolts that hold the exhaust manifold/turbo manifold to the head and it should just slide out. Hopefully.
I think some of the bolts are single-use (toque til yield) type. So you need new ones to get it right.
I was hoping that too. Almost there I hope
1 - 8 of 8 Posts
