How many miles you have.
175kHow many miles you have.
ok i’ll do testing on that and check thoseThis is a guess because I have not had any turbo problems so far (apart from the standard crack in the wastegate seat which has almost not effect on performance).
1) It could be your turbo is not spinning and at 2k RPMs it suddenly starts spinning which would suggest the turbo bearings are partially seized.
2) Maybe your wastegate is not seating properly which maybe your wastegate actuator needs a little more tension to seat it properly (probably would need to replace the actuator). In this case the scraping might be high velocity air flowing through the almost closed wastegate seat.
View attachment 302591 btw this happened recently and i don’t know what’s going on now. i had used a multimeter to check both 02 sensors before and after cleaning them for resistance and voltage, they both are working perfectly fine. I had checked the exhaust system. The exhaust manifold made sure there was no leaks. I had checked the intake, air box and my air filter to make sure it wasn’t dirty or need a new filter. I had checked for any sort of vacuum leaks from every single possible hose under the hood. By the way, this had took in me three days straight of spending 8 to 12 hours straight testing everything I could for anything I could the only thing I did not test and I mean this literally the only thing I did not believe check and test is the fuse box and PCM, what could this mean? Code P0171,code p0133, code p2096 and code U0100-71. all that once
