1 - 16 of 16 Posts
For those of us who don't know the difference between the clutch pressures, can you explain in terms of someone getting in the car and driving it?
Thanks.
Would love to know more about the clutch might make me jump and buy one
Sent from my DROID BIONIC using AutoGuide.Com Free App
Discussion Starter #5
Thanks.
More force equals more holding power. Being we have hydraulic clutch kits, even with more pressure plate pressure, you will not feel much of any difference at the petal.
Thanks - at your prices I'll consider your clutches when my factory clutch needs replacing. Hopefully not for a long time.
Lets say I get the stage 3 kit would I feel any difference at all or would I feel a little bit of firmness at the petal?
Discussion Starter #8
A little more petal pressure, nothing to call a "work out"
You WILL feel a much more engaged/disengaged clutch feel. Meaning your clutch is in or out. This is like all performance clutch kits.
More of an older style European sports car clutch then?
Would it be possible to mix and match, or buy pieces independently?
The stage 1 disc is the best street option, and full face Kevlar discs take a beating...that said pairing it with the stage 3 PP would make for a very strong, yet still smooth street clutch. I had a similar setup in my Talon (full face kevlar and strong PP) and it is perfect for street use as well as 5500rpm AWD launches. A similar pairing would work well for a high hp clutch that retains more street manners than a puck style. The full face also seems to last a lot longer...we've had good luck with them in 850+awhp setups for years of street/strip use.
Discussion Starter #13
I am sure we can work something out when you are ready. However a higher pressure on a stage 1 disc, may reduce the life of the clutch some.
1 - 16 of 16 Posts
