1 - 7 of 7 Posts
2010 Cruze LT 1.8
Right folks, having read nearly every thread marked “clunking” and checked mine over, even the garage cannot find the source.
Convinced it’s from the front right, but so far I have replaced drop links on both sides, new tie rod ends, there is No Play in any of the ball joints or sway bar......
im at a total loss, even under braking you can still here a metallic knocking over small bumps in the road.
totally driving me crazy now, any other ideas folks?
2013 Cruze LT
Strut mount, jack it up and grab the spring and shake it. Make sure car is secured well on the jack or jack stands of course. That was my clunking over bumps, also took me forever to find.
2010 Cruze LT 1.8
Legend, will do mate, I assume Jack it up on the chassis so the load is off the stut.
you meant the Top stut mount ?
2013 Cruze LT
Yep! I grabbed the spring with a glove on and pulled and pushed real hard, tried to jar it, and sure enough heard clunks every time.
Reactions: Blasirl and KirkM71
2016 Chevy Cruze Preimer
Im having the same issue
On your sway bar try to torque the bolts on the links specifically the upper side. See if one is just loose enough to slip occasionally. I had a charger do that to me one time.
2010 Cruze LT 1.8
Strut mounts ordered and being fitted tomorrow.......will update and let you know if that cures it.
To be fair its the only thing left to change.
1 - 7 of 7 Posts
