I've been wanting to upgrade my stock 16" wheels on my 2017 Hatchback RS since I bought it brand new. I prefer OEM wheels, but $2600 that Chevy is asking is too steep.
I finally found a solution that I love but in a price range I could justify. Here goes:
Subaru wheels (18x7, 55 offset) off Craigslist: $300
Bridgestone Potenza RE97AS 225/40R18 from Tire Rack: $329
Hub centric adapter 5x105 to 5x114.3 (20mm) from Amazon: $90
Mount, balance, and TPMS swap from stock wheels: $160
Total: $879
The offset was big enough on the Subaru wheels that it mostly cancelled out the adapter. The end result is my setup only pushes the tires out 6mm father than the stock 18". I pulled the caps off my OEM wheels, separated the bowtie from the cap and then glued it to Subaru caps.
Stock wheels
Subaru wheels I picked up on Craigslist (came off a single owner Outback with 30K miles -- tires were toast)
Got these from Tire Rack for $330 -- Bridgestone Potenza RE97AS
Hub centric adapter from 5x105 hub to 5x114.3 wheel.
Had to pull all four tires to get the TPMS sensors swapped to the new wheels
The hub caps aren't quite as clean as I wanted, but they really give the wheels that OEM look.
Final result.
I installed the Eibach pro kit lowering springs just a few days later. I'll post those results in another thread.
Total: $879
Stock wheels
Final result.
