1 - 11 of 11 Posts
Quite a bit of powertrain warranty left, but the lack of a recorded oil change from 6K to 21K is giving me pause.
Shoud it? Could this be a warranty issue if I need powertrain warranty work ever?
Thanks.
I would ask the dealer if they have record of another one (maybe they can access the OnStar records and see if the oil life monitor was reset in between (not that it means it was actually changed). But the oil life monitor actually might have went 15k miles between oil changes. But I would absolutely ask before buying
Thanks. Carfax actually doesn't even show the first oil change, but the dealer's Service Manager showed me that at around 6K it shows in their system, that another dealer did the "Complimentary 2/24 service". The 21K mile oil change was done at a Valvoline according to Carfax.
I think you'll be ok then. Carfax is only as accurate as the reporting it receives.
How many miles are on the car to begin with? The LS doesn't have the turbo so its not as impacted by oil changes. I will contend however that until recently the dealer oil was total crap. If it were me I'd take off the oil cap and see it it looks like there is excessive varnish/sludge by the cam. Amsoil sells an engine flush that might be a good idea if you decide to purchase the car.
A 2015 with 26K miles...this car is relatively new. Having pause regarding a potentially missed oil change is legitimate however in the bigger picture not a huge issue.
If the car was having mechanical issues it would have been back to the dealership for warranty and/or recall service multiple times by now and that for sure would be reflected on CarFax. Sounds like that's not the case with this car.
As related elsewhere in this forum, what CarFax WON'T show is if the vehicle was in a minor accident or possibly a deer strike and previous owner had it repaired without reporting the VIN.
The low miles and age of the vehicle makes it sound like a lease return. I've had pretty good luck with lease returns in the past...let someone else take the depreciation hit and drive off in a like new car that will last for years.
Rather than a lease return, it could be just an owner that likes to trade for new every couple of years. Either way, absent a record of multiple service issues, I'd buy with confidence and just make it a point to maintain good service records going forward.
Good luck with your purchase decision.
Possibly, but it could also simply be someone who doesn't drive much. I just took my wife's Solara Convertible in for a 10 year service - 41,000 miles. She's the original owner.
1 - 11 of 11 Posts
