Thank you
You just drip the liquid through the brake booster connection? As in don’t use a seafoam with the spray nozzle? I was going to run seafoam through my car before doing the oil change so I just want to make sure I do it correctlyYes has to be run through brake booster vac line my 1.4 splits the line after it comes out so I disconnected the one piece that connects to the intake and dripped it in through there. Also through some in the turbo vac line to was some oily residue in there. Didn't think to video it good idea sorry.
Do you use the seafoam spray for the top engine clean or drip the liquid into the intake?Seafoam is great stuff -I would definitely recommend it at the interval that you ran it through.
Generally, the instructions tell you put put 1/3 a can in the intake (to clean the top of the engine), 1/3 in the oil to clean crud from the oil passages, and 1/3 in the fuel tank near empty to clean injectors. I used it several times on my old car, and it always seemed to run much more smoothly and stronger afterwards. There was always a LOT of smoke too
Not a Cruze, but...
Cool, thanks. Throttle body is already clean, i got some amsoil products on the way instead already. PEA products are betterDude that post was 6 years old, you should have just started a new one. FWIW just put it in your gas tank, its the fool proof way. IMO spraying it into the intake doesn't get you anything on port injected engines like ours. If you want to do meaningful maintenance, clean the throttle body.![]()
Currently PEA products are all I vouch for. They are all fine, I personally use Techron. I was going to say something, but I figured you had already bought the Seafoam.PEA products are better
