1 - 2 of 2 Posts
Hopefully im not posting in the wrong place...
I added a calculated PID to EFILive that I found useful, It takes the "Desired boost pressure" PID and subtracts the Barometric PID from the desired Value.
Copy and paste this into EFILive:
Code:
-- USER.ACTCOMBOOST
return pid("TCDBPR")-pid("BARO,BARO2");
I called it "Actual Desired Boost Pressure", Goes along nicely with the actual boost pressure Calculated PID when viewing the graphs.
Set the unit to Kpa and convert to PSI afterwards (if desired)
Hope this helps.
Code:
-- USER.ACTCOMBOOST
Hope this helps.
Do you happen to know the pid number for desired boost?
1 - 2 of 2 Posts
