I couldn't hear mine most of the time over the engine at idle, but it is definitely noticeable with engine off. This is what a normal one sounds like.
Nope. You can slightly hear that run for about 2 seconds to prime as you switch the ignition on from the rear of the car.I thought that noise was the gasoline pump...
The noise in the video is coming from the front of the car when the brake pedal is pressed & provides vacuum assist for the brake booster when the engine is providing low vacuum (high idle, high valve overlap, cold engine, or turbo is boosting)
Not normal; look for a broken hose or something.In my car, i doesn't stop..that's not normal, right?
Thanks, could it be the switch malfunctioning? I have no broken hosesNot normal; look for a broken hose or something.
Definitely could be; plenty of them act up the other way where the pump doesn't run at all.Thanks, could it be the switch malfunctioning? I have no broken hoses
I think it should sense if Vacuum reservoir is empty of air to stop the pump..
@jblackburn was this video taken with the door open or closed?I couldn't hear mine most of the time over the engine at idle, but it is definitely noticeable with engine off. This is what a normal one sounds like.
Window was down, yeah@jblackburn was this video taken with the door open or closed?
Ok. I don't think I've EVER heard my vacuum pump; However, my car is so heavily modified that it produces almost no vacuum (3 to 5 inHG) with my foot on the brake in gear.Window was down, yeah
