Hello,
My 2014 Cruze has 93,000 miles on it and have discovered the squeaky noise coming from the engine. By a previous post discovered by pulling the dip-stick the noise went away, so the PCV may be an issue, I checked it and everything there is fine its not sucking any air. So, its the crank shaft seal that is the issue and will have the dealer fix it. I have no current codes or check engine lights on at this time so, my question is should I go ahead and replace the valve cover? I have reviewed many videos on this faulty PCV part and it seems to be a major issue on this vehicle. With no modifications done to the original part you can not simply un-screw the plastic top since its welded into the cover. It also seems that no after market parts have been created to fix this issue as well.
Thanks,
