21 - 40 of 69 Posts
If you want a spare that you can drive on like normal you need to get a full size spare with a properly sized tire as well...
My gas cruze came with a compact spare, I sold it for $100 plus traded for the ECO trunk liner and inflator kit. I then used $75 of that money to get a closeout 16in rim from tirerack.com(same size as my cruze came with). I then just paid the tireshop to install one of my old tires when I got new ones.
I feel much better knowing I have no speed or distance limitations if I ever do get a real flat. If I did it again I would have bought a matching 1LT 16in rim so I would have had a spare matching rim as well. I also like having the inflator kit, I've used it a dozen times to air up a tire(goo bypassed).
I am not sure about the GM supplied tire "goo" but I can say with confidence that Tire Slime works well for holes in the tread area of a tire, even pretty large ones. Many desert racers run it in their tires to seal punctures as they race... One day I came out to my Duramax truck (on 37-inch Goodyear Wrangler MT/R tires and true beadlock wheels) and the passenger side rear tire was completely FLAT!!! I don't drive the truck daily so I didn;t even notice until I went to drive off and felt it... Anyhow I start to inflate the tire expecting a small pinhole leak and they is a large hole near a tread block with air flowing out almost as fast as it is going in from my ARB dual head compressor. So I filled the tire with a bottle of Tire Slime I had in the garage for years and then inflated the tire and went for a drive as directed on the instructions. The tire has not leaked again since!!!
Discussion Starter · #25 ·
Mega thanks if it has no interference, that's all I need, rather have it and not ever need it than need it and not have it. Those the cruze lug nuts or do I need different ones?
Thanks Diesel, no caliper rub?.
No, seems to clear just fine. I rotated the tire and didn't hear anything that sounded unusual. I didn't drive it though.
They are the Cruze lug nuts.
COTM Winner
Great to know! This should be stickied...
I will sticky this thread once somebody has actually driven five miles on one.
Reactions: Merc6 and diesel
Tomko, let me get it and I will give it a test run next weekend. I to want to make sure it will work. unless Diesel does it before I get a chance
I probably won't have a chance before you do.
Thought same thing on a sticky. I'm picking up one Monday. Salvage yard closed on weekends. Go figure
Gator, did you get the spare, did you try it out as well?
Good to know, thanks for the test drive and updates!
21 - 40 of 69 Posts
