1 - 20 of 58 Posts
Cruze LT 1.4T Automatic-69F, street tires, 93 Octane (1/4 tank). Only modifications are a K&N Typhoon filter, a ported intake manifold, and of course our Stage 1 custom tuning! The only difference since my last posted time is the addition of a K&N Typhoon intake instead of a drop-in K&N filter.
Text Document Paper
Cheers,
I was seeing ~200 lb-ft of engine torque max and ~180hp max on my runs according to my data logs. On the highway it is not unusual to peak at ~209hp and 220 lb-ft in my data logs. The time I spend idling or stopped with a hot engine while waiting to take a run at the strip causes the intercooler to heat soak, so peak power always seems down on my runs compared to the open road. I can really feel the difference on the road when there is plenty of airflow over the intercooler. I am boosting 23psi all the way to 6500 rpm.
Cheers,
Brian
Cheers,
Brian
Here is an example of the torque reported by the ECM with our Stage 1 tune:
Text Line Font Design Pattern
We can monitor this and all available engine and transmission data in real time on our handheld:th_coolio: , or you can save it (black box logging) to the built-in 6mb memory and review it later on your computer.
Hmmm this is cool. With trifecta I get awesome MPG, but my best time so far has been 15.71 @ 87 mph. I wonder what the difference is? 0.5 seconds is nothing to scoff at!
Awesome numbers!!
Just curious what your ECU is reading for engine torque with your tune? Making me think my ECO manual will hit high 14's
Doubt it. The 2011 Automatics are the fastest Cruzes.
...curious, what was the vehicles' "race weight" for that 15.28 sec/98.04 mph quarter-mile?
...thanks, I appreciate the answer.
I'd love to see what this car would do withe the ZZP exhaust pipes and FMIC.
I'm seriously thinking about doing this. I just cant decide if I want to spend ~$2500 for tune, intake, fmic, zzp down and mid, custom rest, clutch.
It would be badass to see the numbers from that kind of setup though, i agree there.
Sent from my DROID BIONIC using AutoGuide.Com Free App
Awesome numbers!!
You should be able to, especially since you're packing less weight, more aerodynamic, manual. Every tenth of a second matters!
And less aggressive gears and a narrower powerband...All the fastest times for Cruzes are on the Automatics. Gearing, automatic transmisison, and better tires more than make up for the 100 lb weight difference. I haven't seen an Eco beat any of my times yet, and I'm as high as 15.7 seconds.
In theory, the fastest car will be my buddy boats4life's car. 2011 Automatic Eco - If he puts some performance tires on it, it should be able to get close to 15 flat with the same things Brian is running. The Automatic Eco has the identical same gearbox as the Automatic LT, but keeps all the weight / aero mods.
If I get out of work early enough on Wednesday I will hit the 1/4 mile. Considering I keep even with some high 14's cars on the street I think I will do ok...
You better get there early before the gates open if you want to get more than one run in. Let me know if you go, I'll come up there after work.
Discussion Starter · #20 · (Edited)
Yeah with front mount IC I hold 210+ ... However clutch needs love soon I'm going to guess. I want to do intake mod and 42lb injectors next.
210+ torque below 5000 rpm is easy without any mods other than software - 210 at 5250 not possible without modifications. What is your peak torque at 5250 rpm?
Cheers,
Brian
1 - 20 of 58 Posts
