I see the same mpg swings on my CTD. I run a grille block when temps are below 50°.Just curious if anyone has run a warm air intake. Seeing as I have massive drops in instant mpg even fully warmed up during colder weather. Curious if having intake additional tubing run toward manifold to pull heat from there to bump temps would work. 15+ mpg swing in instant mpg on same route holding same speed isn't due to denser air creating higher drag values. I feel are cars run best between 60° and 80°. Curious if anyone has tried this and to what end result?
Isn't that pulling from the same spot as our cruze after res delete?Look at the injen intake for the 1.4 Sonic.
Yeah, but the pipe runs right over the hot engine and warms the air.Isn't that pulling from the same spot as our cruze after res delete?
Kinda funny I was over there earlier looking for this. Solid bashing on a few guys and their close minded opinions on intakes lol
Well then a SRI like i had on my 2012 could be good for you, if you dont do a on the fly modification.I really have zero opportunity to suffer any null effects from heatsoak. My trips are never in excess of 40 miles. No stop and go more than 2 consecutive stoplights...And those are decent distance appart. When I head to a town for shopping it's directly to the store and off long enough to adequately cool to prevent any chance of heat soak issues in the 2-4 stoplights I would see on my way out. Not exactly a city guy. Just kinda hypermile the country roads hypershort trips. Typically less than 15 miles between long enough cool down time to consider car cold. Curious if I could just turn the airbox sideways so bottom tube would be pulling from the motors direction. I think the box would fit sideways in there...Would be easy test may have to try that tomorrow. If it works I won't need any extra parts...Zip ties to secure box. Then would be 30 second pop the hood and twist to put it back. Thoughts or previous attempt at this so I don't waste my time would be great. Still seeing a lot of hate on the wai lol if it works for me I hope I can rub it in lol
I'm definitely not blowing that kinda cash on something that hides under a hood lol you can darn near get a tune for that! Pipe fittings are easy to play with and flex pipe is even easier I can figure something out. Was hoping to see someone else's imperfect designs lolWell then a SRI like i had on my 2012 could be good for you, if you dont do a on the fly modification.
Mine was this one : https://zzperformance.com/sonic/air-intake/cruze-k-n-intake.html
Ya, the best for the price would be just to modify slightly the stock air box.I'm definitely not blowing that kinda cash on something that hides under a hood lol you can darn near get a tune for that! Pipe fittings are easy to play with and flex pipe is even easier I can figure something out. Was hoping to see someone else's imperfect designs lol
Mmmmm, at 45mph the car should get hot rather fast, at least both my 1.4 and 2.0 did.Zero degrees out it takes about 15 to 20 minutes with the heat completely off toggled to 1 to keep windshield clear on idle sections. If I stay backroads never breaking 45 mph except on a neutral coast I hit about 52. That's a 13 miles trek to work. It's just about at normal operating temp when I arrive lol granted that's not adding in wind chill. Sucks the heat out of the car a tick faster than dead air.
Do not do that.Wouldn't having a separator to push some air past the maf undetected create a leaner operation? Or would 02 sensor level that out quickly? Just curious if it's worthwhile to play with the maf at all other than in the computer system? Cuz a simple plastic or metal piece in the tube before maf diverting air around the maf would mean more air being put in but maf only reading the 3/4 or half flow matching that for air fuel ratio. That would I'm turn create a leaner scenario correct?
