Hello again Everyone,
Back in June I was having some issues with my Cruze. Had codes for a vacuum leak, and lean bank codes, etc.
Basically, I ended up replacing the cam cover/PCV valve. I did not replace the intake manifold at this time as I figured I'd try to just get away with the cheaper part, although I did not actually look to see if the check valve in the manifold was gone.
Anyway, as of recently, when braking, using turn signals, changing from park to drive or reverse or any gear, using windows...when using these 'features' the car will flash a few warning lights. Service StabiliTrak comes up on the small screen between the tachometer and speedometer. The traction control light also comes on, a break warning light pops up and also the ABS light. Lastly, and this only happened once for about 10 seconds, power steering had completely cut out while driving on the highway.
Hoping someone could point me in the right direction again...and also if anyone has any idea if these issues could be related to not replacing the intake manifold from my previous issue.
Thanks in advanced for the help!
