1 - 14 of 14 Posts
I was just questioning what you meant Patman.
What's all covered under that 5yr 100K power-train warranty exactly?!
Sent from my SAMSUNG-SM-G870A using Tapatalk
I know you have an auto transmission in a LTZ , it would cover shifting problems or any other type of transmission issues(reverse problems with the manumatic or not going into a gear or failing etc.). For example(I know not an auto), my 2012 Eco(6M) I had the transmission problems that I could not shift to 3rd gear @ 81K. Under the warranty they replaced the transmission. So if you are having shifting problems. Not really sure on the engine, I believe it would cover problems with the BCM/ or problems with the internals of the engine that would cause it not to run properly. Your local dealer will be the final determiner of the problem/issue. Hope that helps.
TYVM!!!
1 - 14 of 14 Posts
