2 things.Hello All!
I’m new to the forum but I’ve been browsing it for years. I’ve had this ongoing issue with my car and am looking for advice.
Beginning in Dec of ‘19 my car started registering that it was overheating. Temp gauge would stop working, fan would go full blast, and AC would be disengaged. I replaced two of the coolant sensors and that seemed to work for anout
When I took it in to get fixed they replaced the thermostat and housing for it.
About a month later later it started happening again. I had read on this forum about disconnecting the negative battery wire to let the computer reset as a potential fix. I did this and it seemed to fix it but about once a week I would need to do it again. Please note that the engine was not overheating, it just said that it was.
I took it in again and they said there was a fault in on of the sensor wires and replaced it. Two weeks later and it was back on it’s BS.
Here’s where it gets interesting. About a month after the issue started up again and I was doing my quick fix the AC stopped working all together. Turned it off at night working and the next morning nothing. Since this happened my car has not pretended to overheat. It’s going on about two months now.
Any ideas of what’s wrong with it?
it’s a ‘13 LS 1.8L 6MT
- Is your cooling fan spinning
- are you low on coolant
