1 - 8 of 8 Posts
I thought the hose leading to the outlet was bad and replaced it. Then it kept leaking. I pulled it off and cleaned things up. By squeezing the main hose I discovered the pinhole leak right on the seam and in the corner, which is what you see in the video (not yet uploaded).
I thought of how many people solve their problems with JB Weld, so I used some RTV that was left over from the valve cover. Hopefully it works good enough.
Automotive fuel system Car Motor vehicle Automotive tire Hood
That will blow out sooner than you think. Replace the outlet asap.
Reactions: jblackburn
I ended up ordering a ZZP outlet. Bc if that one fails, I'll at least get good customer service. I noticed that they use the same photo as the Mitzone one on Amazon.
I just ordered one from ZZP, and it is in fact the Mitzone one. Only thing that I'm wondering about is it came with 6 bolts (3 eTorx and 3 Torx bolts) I guess it's a choice of which you want to use.
Shipping box Packing materials Package delivery Wood Automotive design
Automotive tire Gas Bumper Auto part Plumbing
Brown Wood Material property Beige Tints and shades
1 - 8 of 8 Posts
