21 - 40 of 140 Posts
I got the PAC (this thing is huge!) and the Headlight Harness in, so I am going to try and tackle these this weekend, assuming I can find all the connectors I need...
Well if you need any help there are a couple of people here who have put this in EcoDave has put in two.
Sent From An Antique,
My Original Droid.
Discussion Starter · #23 ·
If only they lived closer to Atlanta LOL
I will ask questions if I run into any, for sure. I think that I might extend the wires on the PAC in order to put it somewhere there is more room, instead of trying to cram it behind the headunit.
If you put it behind the spoy were the PDIM is theres a nice opening there, that's were I have mine I will take pictures tonight since I still have everything apart.
My Original Droid.
Discussion Starter · #25 ·
My Original Droid.
Ok, cool. I will have to check that out, if it saves me time by not having to lengthen the wires then I am all for it.
Sorry for the messiness in the pictures i was in a hurry because i was also doing alignments while installing all of this.
Auto part Vehicle Engine Car Subcompact car
Another angle showing were my wires run.
Auto part Vehicle Bumper Automotive exterior Tire
You can see the harness behind the Stock PDIM
Auto part Vehicle Suspension Car Suspension part
Just showing another angle of the harness
Vehicle Car Compact car Plant City car
This is were my PAC harness sits behind the A/C controls
Reactions: Dragonsys
The other location is to the right of the stereo, above the glove box. it is a tight squeez getting it in but it is a perfect fit.
Discussion Starter · #29 ·
That is where I was originally thinking, but I was going to extend the wires some so I could put it a little further behind the Glove Box where there might be more room.
I will find out once I get it all pulled apart anyway ;)
Thanks guys
If you extend the wires at all I would suggest adding velcrow to hold it in place, with the wires being pulled tight it stays in position really well, but I will warn you it's a tight pull on the wires and getting the radio back in is very tricky. But it will go with a little finesse.
Discussion Starter · #31 ·
I read that in your how-to, which is why I thought about extending them in the first place :)
Discussion Starter · #32 · (Edited)
I got the PAC installed, but now I can't figure out how the passenger side kick panel comes off, so I can run the RCA & Remote under it...
EDIT: Finally got it, the wires are now in the back seat, but it is getting to hot & humid to work much longer, so I'm gonna take a break until nightfall to work on the pulling them into the trunk.
Discussion Starter · #34 ·
I did it with mine and love the outcome of it. It does take some finessing to get it in though.
Sounds like you will be an expert on pulling the seat apart before too long...
Discussion Starter · #38 ·
LOL the backseat has to be one of the easiest pieces I have had to remove for this install yet...
Ok, so the console is all back together. I ran wires for Power & Ground under the Center Console, but I will have to actually hook them up later. Still need to run Power & Ground for the Amp, and then hook it all up in the trunk
