I love physical activies, awesome views, and beer...which is why I only had those 2 ideas haha. Not sure I could convince the girlfriend to white water raft though. We're already hitting the SD Zoo, so 2 Zoos in one trip is a bit much. Any cool museums, sites, big shop areas...I tend to go 50/50 on the super-touristy stuff and the backdoor local stuff.What are you interested in? We also have white water rafting.
I think there's a transport mode that might be a good idea to turn on. Minimize the drain on the battery for those 2 weeks. Worst case, you might come back to a bad battery that will no longer take a charge.Leaving the Cruzer alone at home for 14 days...any thing I should do to prep it for 2 weeks of no running? Silly question I know.
How do you take the Cruze out of transport mode? Start the engine, or is there a special sequence used here as well?I think there's a transport mode that might be a good idea to turn on. Minimize the drain on the battery for those 2 weeks. Worst case, you might come back to a bad battery that will no longer take a charge.
To turn the Transport Mode On/Off:
1. Start the engine
2. Activate the hazard flashers
3. Press the brake pedal
4. Press and hold the Start/Stop button (if equipped) or turn the ignition key to the crank position for 15 seconds (Don't worry, the computer controls the actual starter - attempting to start an already running Cruze won't hurt it.
Same sequence.How do you take the Cruze out of transport mode? Start the engine, or is there a special sequence used here as well?
