What did you do TO your Cruze today?
302778 Views 2280 Replies 328 Participants Last post by  Thebigzeus
Post what you did to er and maybe even a picture to accompany it.
Today I just washed it and did a quick wax job. It was pretty dirty from about 5 commutes to work!
1281 - 1300 of 2281 Posts
Drove 500 miles to my nephew's house to ring in the new year. Before fireworks and festivities, my car was overdue for an oil change, tire rotation, and top off the wiper fluid. Went over 7500 miles and the OLM had been on 0 for part of the drive, but I was there within 600 miles of when the CHANGE ENGINE OIL SOON message first appeared on the display.
To work then menards then home then bought a k&n intake :cool:
I replaced the cruise control switch on the wheel on my 2013. I have put enough use on that switch to rub the rubber selector knurling knob in to a sticky rubber wheel. Probably needed a new cruise control on/off switch too, turning on and off the trifecta tune dodging crazies on the German autobahn. Man I can’t wait to get back to the States ...
Got my fog light kit installed today. Tomorrow I'll swap the cabin air filter. Gotta call the dealer Monday and schedule the appointment to get the BCM programmed
Thats one thing I have to check is my cabin filter
I bought the Fresh Breeze one. I used them in my Silverado and they were awesome. A lot easier to change in the truck though lol
Designed speaker adapters to cut out on the cnc:cool:
Got the cabin filter swapped. Looks like it was about time ?‍♂
285130
285132
Id say so !
Got my k&n intake in the mail and played around with some different pages on my Ultragauge v1.2.
Installed my k&n intake and dry charger. Ssssshhhhhh choooooo :p
Daughter helped me replace the lower Catalytic Converter, yesterday.
Pulled off the Upstream O2 Sensor, since it looked clogged when I replaced it in October. Looked almost as bad as the old one. I'm going to reset the codes, after my wife and son return from the base chapel's youth retreat, this weekend. May have to replace the upper CC and the Upstream O2 Sensor.
The Bomb's total miles is about 87k, but I personally just passed 55,555.5 miles.
I was able to take a practice pic, but the camera died just prior to the moment with no where to turn off... bummer for me.:cry:
285343
Added borla s type exhaust and the trifecta tune.
With that, k&n intake and brisk racing plugs, this car is running great!
The Bomb's total miles is about 88k, but I personally just passed 55,555.5 miles.
I managed to take a little video last summer when my 02 Silverado rolled over 200k miles (321868km for you metric types).
Also left my car at my local independent shop today. They programmed my BCM for my fogs, did oil and filter and tire rotation. Currently at 11091mi (17849km)
Started to replace the wiper transmission for the second time, but found I only needed to tighten the wiper arm bolts :rolleyes:
Also re-cleaned my positive battery terminal - for the third time.:(
087036 mi.
Did this...
Vehicle Auto part Engine Car
Also started installing my Garmin backup camera.
Today, I fixed an oil leak that stemmed from me not getting the oil return tube fully tightened from when I reinstalled the turbo, which I removed for the purpose of replacing the coolant line that runs behind it.
I tried to replace the oil return tube without removing the cat. That was a mistake. Oil was dripping right on the cat and making a hell of a smoky mess.
Getting that front cat retaining nut off was a serious piece of work. Halfway off, the rear side retaining clip decided to stop retaining so everything was just spinning and not coming off.
Luckily, I was able to remove the band clamp along with the 3 nuts that connect the cat to the exhaust pipe. There was also another bracket but that came off easily.
So with all that off, and the O2 sensor harness disconnected, I was able to move the cat around and there, underneath, I spotted my opening. I had just enough room to get a long sawzall blade in there and was able to cut that last stud and free the cat.
With the cat removed, the source of the oil leak was obvious and I was able to tighten up the oil return tube.
The cat currently has 3 out of 4 connection points in place and there’s no unwanted movement.
So dirty...
Got my backup camera installed
285387
...and aimed
285388
