What did you do TO your Cruze today?
302183 Views 2278 Replies 328 Participants Last post by  Blasirl
Post what you did to er and maybe even a picture to accompany it.
Today I just washed it and did a quick wax job. It was pretty dirty from about 5 commutes to work!
1721 - 1740 of 2279 Posts
My Autometer boost gauge just arrived from Amazon, I’ve got a threaded plug in my ZZP upper charge pipe... just need to figure out how and where to mount it. I got the Autometer mounting cup with it also. So that’s today project.
Bnr has a nice but pricey mount that fits in the dash vent.
This works great!
This works great!
I was looking at that but I thought it would look odd having only a single gauge in there and I really couldn’t think of another gauge I really needed. Running the air line to it there would be a pain the the rear!
I use to use my phone with a OBD Bluetooth adapter for boost but the shift light I bought plugs into the ODB port and doesn’t work with a splitter. If I cant get it mounted someplace else I might go with the A pillar setup.
Thasks!
Oh, I didn’t look at his site, thanks for that info I will check it out!
Thasks!
It's alot easier than you think. I put a aeroforce Interceptor in my other pod.
Cool, I’ll look at what is out there. Of course I run to the grocery store and the passenger window won’t go up, it will go down but it gets stuck half way up. I managed to pull it all the way up and it stayed. It looked like it jumped the track but won’t know until I take the door panel off.
Went for a slip and slide.
Went down this icy side road and the car rotated 90 degrees to the left by the time I cuaght it and got to watch the world go by sideways for 10'. Proceeded to over correct into a 180 to the right for another little bit before straightening out with a couple fish tails
Took mine on it's first trip to town since I dug it out. Slicker than crap out there, but the Blizzaks did their thing and made it an easy trip. Only issue I had was snow packed in behind the hubcaps threw the wheels out of balance. I took the hubcaps off in the Sportsman's Warehouse parking lot. Problem solved. Besides, black steel wheels are fine for snow tires.
Thasks!
Not that bad to install. I had mine apart two days, I could still drive, but I had alot of other things going on in there as well. A few hours should do it.
How-To: Install gauges in a ZZP Pillar Pod A-Z Part 1
Changed both front hubs, and re assembled in a snow storm.
BBRRRR!
Took off the DDMworks leaky throttle body spacer and replaced with a BNR, boost test holds pressure for SO much longer.
Did you document - pictures - what the differences were? I have the DDM Works spacer and have considered the change as well. I need to do another boost leak test though first.
I brushed a foot of snow off of it's glossy exterior.
3
Getting the new rim put on. Front drivers side is cracked.
290761
290762
290763
Did another 900km round trip throught the country mostly overnight in a snow storm. Had fun, exercised my hand brake in some empty parking lots. and enjoyed sliding on the back roads too. Also exercised my snow shoveling capabilities with my car shovel.
First beaching I needed the shovel for. there were a series of 90 bends that went on forever as the road conformed to the lake front. Just had to try and touch the corner on my way by one bend and ended up getting sucked into the snow bank as my rear end came round, not bad quick shovel and I'm out n rolling 10 minutes
Second time that trip there was a blind corner overlooking a downtown core in a valley. Naturally assuming the road would of continued, but nope. I was thankfully slowing down for the veiw but once the decent started there was no making the turn. Lodged the car up a bank of plowed snow. Shoveled forever on that one, got to a point the tires were bout 4" off the ground. Eventually lost my shovel trying to get the snow out from under the engine and melted the shovel on the exhaust as the car dropped down. Another thankfully I was able to get out after a little more hand digging.
We had a similar test of the snow-fording capability of the Cruze on Tuesday.
Took my mom out to dinner for her birthday to a place about 30 minutes away, but somewhere we've been numerous times, so the area is very familiar to me. A major road with an interchange to I-75.
Well, they're turning that into a diverging diamond, so it is under some heavy construction, which was not present the last time we were there (probably a year and a half ago, at least). Normally it is a divided highway (Michigan, so we have turnarounds every so often - Michigan lefts), but now, due to the construction they have EB switching over to the WB side East of the interchange, and then back over to the EB side after the interchange. On that WB side, you also have WB traffic. Either way, dumps us back onto EB, where the restaurant is, just before the turn into said restaurant.
Confused yet?
Well, leaving, I turned right back out onto EB, and then went to make a turnaround back to WB...except the turnaround we've always taken...suddenly, and worse - with no signage - is a crossover from WB onto the EB side, to go WB...while traffic on the WB side was also going WB. Given it was night, the road was covered in salt, and I had no WB traffic at the moment, to me, that looked like the turnaround I've taken forever...because it used to be.
Until I saw the headlights. I instantly pulled to the right into the temporary island, which was full of the 6-8" of snow we just got the night before. Thankfully, I believe that is actually just the real left lane of the road, blocked off because of the temporary crossover, so there were no curbs. But still...quite a lot of snow. We have winter tires...but this is their seventh season, so I was real worried about getting stuck, because I had to stop - you know, not to get hit by traffic in the lane I should have been in going EB. Where I was at I was just spinning, but was able to back up a few feet, and get going forward and hop back onto the road without issue.
So...whoops...glad there were no cops around, though I'd absolutely have argued about just what in the hell they did there, because what I did was far too easy to do, and neither myself nor my wife saw any signs stating it was suddenly the wrong way.
But what I do know is: the snow tires are fine and we don't need new ones just yet. :ROFLMAO:
What a mess.
Getting the new rim put on. Front drivers side is cracked. View attachment 290761 View attachment 290762 View attachment 290763
I told you, you gotta stop jumpin' curbs!
Got stuck in the snow the other day. My Dad's Canyon had to pull me out. Just thought I'd mention it.
I wouldn't be admitting that. :LOL:
Well I don't blame myself for it. It was horrible weather, I had to close the store I was working at early just to make sure everyone could get home safe. You probably know, 'cause the storm covered basically the top half of Indiana.
