First - pictures from the fill up.
View attachment 5098 View attachment 5099 View attachment 5100
This tank started with a 15.3 gallon fillup with an estimated 3/4 of a gallon in the tank to start with. This means the Cruze ECO MT's total fuel capacity is ~16 gallons, despite the advertized 12.6 gallon tank, giving it the same tank as the other Cruze trims. The additional half gallon is the fill pipe.
I didn't see the fuel needle move for 250 miles. This is to be expected for a 16 gallon tank with in a car getting 47 MPG as this is how far you have to go to get the fuel level down far enough for the gage float to start moving. Once the fuel need started to move I discovered that the range at any time varied very little; 740 - 750 miles. This indicates the gas gage needle to drop linearly with the distance driven. I had suspected this but this was the first tank I actually kept an eye on the relationship between Trip A, DTE, and the needle on the gas gage.
When I filled up, I had been sitting on "Low" for DTE for about 20 miles. Since the "Low" triggered at 698 miles, this means I had about 25 miles, or about half a gallon, to empty. Given that I started at 16 gallons, this means I used 15.5 gallons of gas, for a 46 mpg tank. The DIC reported 15.1 gallons used, which is 2.5% low. Given that I drove up to Rocky Mountain National Park and back on this tank as well as 360 miles of commuting, this is actually rather accurate.
Deceleration Fuel Cutoff (DFCO) really works. When I drove up to Rocky Mountain National Park I dropped from an average of 48 MPG to 38 MPG. Coming back I made it back to over 46 MPG for the tank. My car was in DFCO most of the way back. Also, DFCO works on the Cruze ECO MT from idle to well over 3000 RPM. I discovered this using engine breaking. When the car comes out of DFCO at high RPM, there is a slight surge of power when the injectors are restarted. I had no power surges until I was close to 4000 RPM. The ECO MT will coast a long way in 6th gear, especially when approaching idle RPMs - neutral is definitely not needed to coast in this car.
The Trip Odometer MPG and the Game display appear to never show the same MPG. Obviously once the Game display starts its running average the two won't show the same. The Game display in my car always shows a lower mpg than the trip odometer.
Finally, my first click-off today was at 11.4 gallons. Given that I had about 1/2 gallon when I started filling today, that means the first click off was at 11.9 gallons, half a gallon below the vent system's guick shutoff at 12.6 gallons. Without actually seeing how the fuel pump assembly's vents are placed I would guess the gage float covers a gallon of the tank's capacity. This also correlates with the fact that from 60 miles to empty to my fill up the needle sat on or just below the empty line, explaining why the car is unable to give you a DTE when you're down to a gallon or so of fuel.
Before anyone says that filling into the fill pipe can cause problems with the vapor recovery system, I'm aware that there is a small risk of this. When I did the previous fillup, I was trying to fill the actual tank and I stopped before the gas reached the fuel nozzle, but not by much. I wanted enough gas for my road trip as well as commute most of the following week. I definitely did not expect to hit 700+ miles on the tank. I was hoping for low 600s. Those few ECO MT owners who are getting better than 50 MPG should be able to get close to or more than 800 miles on a tank. This is by far the best range of any personal vehicle I have run across.
