1 - 4 of 4 Posts
Hey guys,
I am trying to locate a 12v key on source (10-15a) to power my snow performance meth kit and trying to make things as clean as possible. I was thinking about using a fuse tap (or add a fuse) into the fuse box in the engine compartment since its right near the controller for the pump, however I am not sure if any of those fuses are key on or if they always have power running through them.
I was thinking about fuse number 11 which according to the alldata is the MAF/IAT sensor fuse which is 10a. I would like to avoid having to wire inside the cabin if possible for the sake of simplicity.
Any ideas?
Hi I'm installing a gauge and I can't tap the fuse inside. I have to tap a fuse in the engine do you have any suggestions? I want it to turn on with the key (btw)it's just for the light bulb on the gauge. I can't tap inside because I have them tapped already
1 - 4 of 4 Posts
