1 - 4 of 4 Posts
Sorry for the newbie question, im not too engine savvy. What is the tube or whatever coming out of the right side of the engine wrapped in black tape like stuff. I noticed today the tape is peeling apart. In the pic it is right to the left of the battery, second tube or whatever it is.
Wiring conduit. If you follow the ends you'll see wires coming out at various points and several connections into the battery area. The tape is high temperature electrical tape. Some of mine's loose as well.
I would rather look at that wire harness and crappy tape where they ran it, than the alternative some cars use where its ran under the battery tray. With it under the battery tray there is a risk if your battery leaks it could corrode the wire harness.
Discussion Starter #4
Okay. Just wanted to see what it was. Thanks guys.
1 - 4 of 4 Posts
