There is a better version of this chart below in post number 3:
I have been following a few threads that speak to the data in the chart below. I have went to a number of sources, primarily GM Authority, to glean this information. That said, this was an arduous process and I started to get a bit cross-eyed. If you see any glaring mistakes, please let me know along with a source or two and I will fix it. I know there are a number of issues that needs to be addressed.
1. 2016 vs 2016.5
2. 2019
3. Model/Trim levels possibly in all years
Note: Eventually I would like to add the Verano and the Sonics to this chart as well. It might be possible to add the international versions too, but I will probably leave that to another.
Type of TPMS frequency:
315 MHz (2011-2015, 2016 limited edition) 433 MHz (2016-2019)
Enjoy!
Not sure what tire/rim went with what trim/model for 2019, but it seems as if those are all of the choices.
That was difficult! The forum does not like spreadsheets at all. Took forever to fix this.
1. 2016 vs 2016.5
2. 2019
Enjoy!
Model | Tire (metric) | Tire RPO | PCD (mm) | Rim Width | Offset (mm) | Center Bore (mm) | Rim RPO | Lug Threads (metric) | Load Index | Speed Rating |
2016.5 | ||||||||||
L | 195/65R15 | 5x105 | 6 | +41 | 56.6 | M12x1.5 | 91 | H | ||
LS | 195/65R15 | 5x105 | 6 | +41 | 56.6 | M12x1.5 | 91 | H | ||
225/45R17 | 5x105 | 7.5 | +44 | 56.6 | M12x1.5 | 91 | H | |||
LT | 205/55R16 | 5x105 | 7 | +41 | 56.6 | M12x1.5 | 91 | H | ||
LT Hatch | 205/55R16 | 5x105 | 7 | +41 | 56.6 | M12x1.5 | 91 | H | ||
225/45R17 | 5x105 | 7.5 | +41 | 56.6 | M12x1.5 | 91 | H | |||
Premier | 225/45R17 | 5x105 | 7.5 | +44 | 56.6 | M12x1.5 | 91 | H | ||
225/40R18 | 5x105 | 7.5 | +44 | 56.6 | M12x1.5 | 88 | V | |||
RS Hatch | 225/45R17 | 5x105 | 7.5 | +44 | 56.6 | M12x1.5 | 91 | H | ||
225/40ZR18 | 5x105 | 7.5 | 56.6 | M12x1.5 | 88 | Y | ||||
2017 | ||||||||||
L | 195/65R15 | 5x105 | 6 | +41 | 56.6 | RRL (Steel) | M12x1.5 | 91 | H | |
LS | 195/65R15 | 5x105 | 6 | +41 | 56.6 | RRL (Steel) | M12x1.5 | 91 | H | |
225/45R17 | 5x105 | 7.5 | +44 | 56.6 | RSC (Aluminum) | M12x1.5 | 91 | H | ||
LT | 205/55R16 | 5x105 | 7 | +41 | 56.6 | RS1 (Aluminum) | M12x1.5 | 91 | H | |
LT Hatch | 205/55R16 | 5x105 | 7 | +41 | 56.6 | RS1 (Aluminum) | M12x1.5 | 91 | H | |
Premier | 225/45R17 | 5x105 | 7.5 | +44 | 56.6 | RSC Aluminum | M12x1.5 | 91 | H | |
225/40R18 | 5x105 | 7.5 | +44 | 56.6 | RQK / RSZ (Aluminum) | M12x1.5 | 88 | V | ||
RS Hatch | 225/45R17 | 5x105 | 7.5 | +44 | 56.6 | RSC (Aluminum) | M12x1.5 | 91 | H | |
225/40R18 | 5x105 | 7.5 | +42 | 56.6 | RQK / RSZ (Aluminum) | M12x1.5 | 88 | Y | ||
2018 | ||||||||||
L | 195/65R15 | Q1M | 5x105 | 6 | +41 | 56.6 | RRL | M12x1.5 | 91 | H |
LS | 195/65R15 | Q1M | 5x105 | 6 | +41 | 56.6 | RRL | M12x1.5 | 91 | H |
225/45R17 | Q1R | 5x105 | 7.5 | +44 | 56.6 | RSC | M12x1.5 | 91 | H | |
LT | 205/55R16 | ?? | 5x105 | 7 | +41 | RS1 | 91 | H | ||
225/45R17 | 5x105 | 7.5 | +44 | 56.6 | RSC | M12x1.5 | 91 | H | ||
LT CTD | ?? | RS1 | ||||||||
LT Hatch | 205/55R16 | 5x105 | 7 | +41 | 56.6 | RS1 | M12x1.5 | 91 | H | |
LT RS Hatch | 225/45R17 | Q1R | 5x105 | 7.5 | +44 | 56.6 | RSC | M12x1.5 | 91 | H |
225/40R18 | 5x105 | 7.5 | +42 | 56.6 | RSZ | M12x1.5 | 88 | Y | ||
LT Redline | P225/40R18 | REW | 56.6 | RQK | M12x1.5 | |||||
Redline Hatch | P225/40R18 | REW | 56.6 | RQK | M12x1.5 | |||||
Premier | 225/45R17 | Q1R | 5x105 | 7.5 | +44 | 56.6 | RSC | M12x1.5 | 91 | H |
225/40R18 | 5x105 | 7.5 | +44 | 56.6 | RSC | M12x1.5 | 88 | V | ||
Premier Hatch | 225/45R17 | Q1R | RSC | M12x1.5 | ||||||
2019 | ||||||||||
205/55R16 | 5x105 | 7 | +41 | 56.6 | M12x1.5 | 91 | H | |||
225/40ZR18 | 5x105 | 7.5 | +42 | 56.6 | M12x1.5 | 88 | Y | |||
L | ||||||||||
LS | ||||||||||
LS Hatch | ||||||||||
LT | ||||||||||
LT RS | ||||||||||
LT Hatch | ||||||||||
CTD | ||||||||||
CTD Hatch | ||||||||||
Premier | ||||||||||
Premier Hatch |
