Sorry you can delete this if im posting too much im just worried and didn't get much from my other post can't find how to delete it.
2012 Cruze lt 1.4L 215,000km
Took to mechanic they cleaned air intake out found orange nipple which is good
They said pcv valve causing pressure so replaced it
Came home noticed my oil pan soaked. Cleaned it. 10 minutes later running idle oil was starting to soak pan again
2 days later now I keep an eye on it....no oil leak... Where the oil leaked the day of is dried up now. HOWEVER I have two pictures I took I can't see anything above it very well. If someone has thoughts of what's going on i would be forever grateful. I thought it's oil pan gasket. But it seems to be wet above the oil pan as well. Only just above if I feel higher it gets dry. Note this is right underneath the belt side of the engine. which you can see in the pictures
Worrying me just in the fact I don't have a mechanic I trust and I don't want a gasket changed when it doesn't need to be and there is another issue.
Thanks
Thanks
