Great job researching.
Out of your final 3 choices, I have tested the first one. It had a pretty good pattern, bright hot spot but unfortunately more glare.
This was taken at close range so the beam hasn't had quite the chance to develop but you'll notice a 60° vertical strip of light left center. This strip may lay right over the direct eye path of oncoming drivers.
Top is LED
Bottom is halogen
The second choice I am weary about due to the 4 chip array. It's too long and may result in an focused light pattern.
The third choice I personally would ignore. First of all, the page does not even show you a H13 bulb. It's a H4. And secondly the design of this bulb looks to be a copy of two other Chinese marketed bulbs combined in one. Yes, the Chinese copy each other.
· COTM Winner
Top is LED
Bottom is halogen
@evo77, Are you planning to test the DD SL1s when they come out?
If they turn out as you're expecting, those would probably be the best choice here, yes?
Just like many other things, it seems there's no perfect world with these LEDs. I went ahead and ordered the VK-5S H13 9008 8000LM LED Headlight Conversion Kit.
As long as these work out, I'll probably follow up with a set of their H8/H9/H11 for the fog lights.
https://www.amazon.com/gp/product/B01FI0S49U/ref=ox_sc_act_title_3?smid=A3G7TLYY81PTV&psc=1
However, I'm remotely intrigued with these dual color lights. Probably a little gimmicky for a 49 year old though, lol :)
These look a lot like Philips chips to me. I don't see silicone lens on them.
https://www.amazon.com/gp/product/B074Q6X54L/ref=ox_sc_act_title_1?smid=AQV2X9R9RK79&psc=1
I'm not sure why these cost so much more. They are Philips chips.
https://www.amazon.com/gp/product/B076DR4GHH/ref=ox_sc_act_title_2?smid=A1P223EEC6797V&psc=1
I'm not sure. They are only available in single filament style at the moment. By the time the dual filament H13 is released (which could very well be another year or so) I will have already retrofitted a set of LED projectors. Which will be superior in light output over any pnp LED bulb.
Our Dodge minivan uses H11 so I'm debating on giving the SL1 a try. But I've already got plans for a LED projector retrofit too, lol. It may be a good test because the current LED bulbs we have in there now are pretty **** good.
The wife's van has EKLIGHT K8 H11 bulbs. Twice as bright as halogens. I've been meaning to take video of the beam at night. It's very impressive for a reflector system. If it wasn't for the finicky canbus flickering (very faint) I'd probably stick with these and skip a retrofit.
Here is my image of the Caravan headlamp.
