I'm working on a headlight retrofit, and in order to buy the right bulbs for my projectors I need to know which lights the stock Cruze uses for DRl's (EX: low beams, high beams at half brightness, etc.)
Thanks!
Thanks!
Low beam, using PWM to dim them.
Low beam, parking, and turn signals are driven directly from the BCM. High beam is controlled by the BCM though a relay.
