1 - 13 of 13 Posts
Hi. Have a coolant leak on this part. Cruze diesel 2014. It's part of the coolant linkage back of the engine near the starter. Can you help me identify this part. Thanks.
285870
Discussion Starter #3
Thanks for the reply. Anybody else had that problem? The coolant seems to leak just beneath the egr. Could it be the egr cooler that's leaking? It's not a big leak because I never saw a drop of coolant on my garage floor and the coolant is cooked on the engine. Any inputs are appreciated. Thanks
I believe that would be the EGR cooler, yes.
The fittings on the cooler where the hoses go to tend to crack or wear out. They are replaceable...
If the cooler itself is going orrr the it’s coming from a weep hole that’s a big $600 yikes and I’d probably just ignore it unless it gets really bad.
I accidentally loosened a bolt around the EGR valve and coolant came out. I would get a hex bit (I don't remember the size) and make sure they are tight.
Just for your knowledge, if you do an EGR delete, you do not remove the valve, just the pipe on the other side of it.
Discussion Starter #7
Good to know. I planned to remove the egr and clean it and get acces to see from where it's leaking. Thanks.
Holden Cruze 1.8L 2012. 63k miles odometer (15-03-2020).
There is a product that uses 'liquid glass' that you add to the coolant overflow tank. Let it idle for 10 minutes with heater on full then go for a 10 minute drive without heater or AC on.
Check this video. Do not let the video title deceive you, Scotty as awesome his advice is, has to use clickbait...
In Australia I used "Nulon Radiator Engine Block Stop Leak" which also has kevlar. Over a period of one week the leak from my water pump reduced to a few drops a month when parked. Also, keeping your coolant reservior half full helps reduce vapor pressure as it leaves a cushion of gas to absorb said pressure. You have to add the dosage of the stop leak everytime you do a coolant change.
Having failed that you need to replace whatever is the source of the leak.
I'd never put any of that in a vehicle - I did it once in my Cobalt and I still seemingly deal with the effects roughly a decade later.
2014 Chevy Cruze Turbo Diesel “49000 miles”
What do you mean by “If the cooler itself is going orrr”????
1 - 13 of 13 Posts
