Does it go away after a minute?
Some whooshing noises are normal as the A/C system is first engaged and refrigerant changes pressure.
Might be a bad expansion valve. My 2012 had one replaced under warranty.
A set of gauges on high/low sides will be needed to confirm.
many thanks for your help, I just replace cabin air filter recently and found out a lot leaves in the old one, maybe leaves, I'll just leave it if I cant figure it out this weekend.
