1 - 20 of 27 Posts
Need some advice here.
I performed my first oil change at 7,500 miles and used Pennzoil Platinum Euro 5W-30 + OEM GM oil filter about 2 months ago. I drive a lot and because I am about to hit 14,300 miles, the time has come to research other Dexos 2 approved synthetic oils and possibly switch oils (nothing wrong with Pennzoil) once I cross the 15,000-mile mark. Has anyone with the 1.6l CDTI stuck to the 7,500 OCI or gone further out? Coming from the world of VW (gas and TDI) I'm used to their 10,000-mile OCI and find it to be more than adequate for most modern fully-synthetic oils. Should I run the Pennzoil Platinum Euro 5W-30 past the 7,500 OCI (15,000 miles) and wait until I hit 20,000 miles before changing to one of the two oils below and then going for a 10,000-mile OCI?
Ideas:
1.
  • Go with FUCHS GT1 PRO FLEX (Dexos 2 approved) 5W-30 synthetic oil when I hit 15,000 OR push next oil change out to 20,000
  • Comes in 5 L / 5.28 quart jug for $38.90 (no tax & free shipping) over at ECSTuning.com
TITAN GT1 PRO FLEX SAE 5W-30
is a premium engine oil designed to meet the requirements of modern gasoline and diesel engines of many different car manufacturers. It utilizes the new XTL-Technology® which offers high performance over the full temperature range. The unique lubrication properties of XTL-Technology® offer significant benefits in highly stressed engines, especially in downsized components or engines with Stop-Start systems. XTL-Technology® is proven to promote lower fuel consumption when compared to the same SAE-class.
2.
  • Go with Liqui Moly Top Tec 4600 (Dexos 2 approved) 5W-30 synthetic oil (if I can find it stateside) when I hit 15,000 OR push next oil change out to 20,000
  • I've used Liqui Moly exclusively on all my VW's for years and have nothing but great things to say about their products
Liqui Moly Top Tec 4600 (Dexos 2 approved) 5W-30 synthetic oil - Article number: 3755
Optimum for modern gasoline and diesel engines with multi-valve technology, Valvetronic, and turbocharging (with or without charge air cooling). Especially suitable where there are long intervals between oil changes and heavy-duty engine requirements. Also suitable for gas-powered vehicles (CNG/LPG). Tested safe with catalytic converters and turbochargers.
GM's 7,500 oil change interval (OCI) just feels like a premature distance to change out good synthetic oil and would like to know what everyone else thinks/feels.
In case you are wondering, we had people running the AMSOIL 5W-30 Improved ESP to 15,000 mile intervals regularly in the Gen1 CTD. We have one member who had 90,000 miles about a month ago on the same change, and is probably pushing close to 100k miles by now, on the same oil (total 5 quarts of top-off oil in that 90k-100k miles), with just regular filter changes. Tuned/deleted, to be specific.
AMSOIL costs a little bit more but offers unrivaled protection. Just offering it as an option, if you're interested.
Nobody can give you an exact answer for your driving conditions but I suspect if the new 1.6L isn't washing a lot of diesel fuel down into the crankcase you might very well be able to run a little longer. Best bet would be to find a reputable oil testing lab and send a sample in at 7500 miles and see how it looks, then gradually extend it out and retest.
Why does the Fuchs clearly say this Oil is not for GM Cars?
Not sure about that. It's on the Dexos 2 approved list.
I've heard great things about AMSOIL. How does it compare or better yet what makes it so much better than the FUCS or Liqui? Not a bad idea of having my oil tested.
I drive about 90% pure highway miles at an average of 70mph / 160 miles to and from work daily. It's been hot as heck in Jacksonville (where I work) with average temps being 90-96F. Rarely does it see bumper to bumper traffic. This car is purely a true commuter car.
Subscribed to hear the input / opinions / facts.
Although perhaps this should have been in the diesel specific forum?
The only thing I would be hesitant about is voiding the warranty on the engine. For example if the OCI shows 0 percent with 8000 miles on the oil yet an analysis says it's still very good so one runs it another 8k.
Do this a half dozen times.
Then suddenly let's say the camshaft snaps which in turn wipes out the head, piston etc etc.
GM will likely want to see your maintenance history and proof.
What will they think about all this?
Best believe given GMs track record with warranty and denial they'd love to use this as the reason the engine had failed even though once could argue it had nothing to do with it.
Perhaps this experiment would be best left until the engine is out of warranty?
Just my $0.02 on this. Take it for what it's worth.
FUCHS is pretty slick. Finally found the page for their U.S. based products and nowhere does it claim to be fully synthetic so this might not be acceptable in the North American market anymore?
https://www.fuchs.com/us/en/products/product-program/automotive-lubricants/
Specifications
ACEA C3
API SN/SM
Approvals
BMW LONGLIFE-04
dexos2TM (GB2C0209075)
MB-APPROVAL 229.51
MB-APPROVAL 229.52
VW 502 00/505 00/505 01
FUCHS Recommendations
FIAT 9.55535-S3
FORD M2C917-A
GM-LL-A-025
Very good base oils and very good additives. Designed not to meet minimum performance specifications like you'll get from some oils, but to be the best it can be in the market. That's why, in applications that are rarely rated for over 15k miles, this oil was able to go well past 90k miles (next oil analysis will tell us just how much past) without any concerning levels of oxidation (deposit formation), acidity (TBN), or metallic wear. It's a solid product. It's more expensive, but it's solid. I can't comment much on how it compares to Fuchs or LiquiMoly. Those are generally decent brands as well.
If the oil analysis says that it's still good, the dealer has to prove that your modification caused the failure. This is interesting since GM is already replacing wiped out cams on 5.3L trucks with their own oil. Mechanical valvetrain failures in modern engines are RARELY ever lubrication related. If the camshaft snaps, that's a hard failure that would never be blamed on the oil. I like to think about actual documented issues with these engines than come up with rhetorical examples of things that have never been reported.
Maybe Fuchs doesn't call hydrotreated oil 'synthetic', like Castrol and Mobil do?
Nailed it.
Specifications
ACEA C3
API SN/SM
Approvals
BMW LONGLIFE-04
MB-APPROVAL 229.51
MB-APPROVAL 229.52
FIAT 9.55535-S3
FORD M2C917-A
GM-LL-A-025
If it meets the minimum performance specs from VW, MB, and BMW, is it really worse than products that are called "full synthetic?"
Keep in mind, "full synthetic" means nothing, literally. An oil can have 30% conventional base oil as additive carrier and the rest cheap group 3 and still be called "full synthetic," while another oil with 100% high end GTL based group 3 will have the same label.
I understand, thanks. I think this Fuchs Oil was listed fully recommended as a Dexos2 product for the European markets when G.M was still using the blended Dexos. Would you use this now is the question?
Yes, I would use it, but since I know the capabilities of AMSOIL as a fact, I would use AMSOIL instead. I don't think Fuchs is a bad product, I just have exceptional experiences and nearly unbelievable oil analysis reports with AMSOIL.
i dont keep track of miles i just change it when the oil life meter is around 10-15% or so
Reactions: quailallstar
The 7500 mile is not based on oil breakdown, it is based on fuel dilution of the oil. All DPF equiped Diesels that use the engine primary injectors to dump fuel into the exhaust for DPF regeneration suffer some amount of fuel dilution in the oil. That dilution will cause a change in viscosity and lubricant capabilities of the oil. If you delete emmissions, you won't have that issue. I would NOT go past 7500 without an oil sample that shows you have little to no fuel dilution of the oil, and frankly with a mere 5 Qt capacity, the cost of an oil sample won't make much sense to get maybe another 2-3k out of the oil. It DOES make sense for my Pick-up, because it has 12 Qts, or 3 Gallons of oil to change. I typically go only about 5-6K for changes on the Cruze Diesels I have, and you need to monitor for rising oil levels on these cars due to fuel dilution from Regen events.
Oh, I should also point out, the VW 10K interval was with a car that was cheating emissions, thus doing fewer DPF/LNT regeneration events, and less fuel dilution. You should not use that as a benchmark for a car that complies with emissions standards. If you want to get me going on VW, ask about the design of their high pressure fuel pump.
While it is normally true that DPF regen cycles cause fuel dilution, this hasn't proven to be the case with the Gen1 Cruze turbo diesel. I've seen several oil analysis reports on bone stock CTDs showing that 15,000 miles on AMSOIL on these engines is perfectly safe. We also haven't seen rising oil levels due to that fuel dilution.
Feel free to peruse the oil anaylsis reports posted in this thread. The overwhelming majority of the oils are still in the same viscosity range as they were when new.
https://www.cruzetalk.com/forum/201...ssion/48818-oil-testing-anayslis-diesels.html
As I did say, don't extend the interval without testing. The Regen frequency is highly variable. I had 2 gen one cars, they did significantly different intervals in the same driving with the same fuel. I now have 2 gen two cars, and they also have significantly different Regen frequency, in same driving and fuel. Fuel dilution will be dependent upon Regen frequency, and interrupted regens. Unless these are closely monitored for trends, you could be making a guess at actual fuel dilution. It's certainly up to each how they wish to proceed, but be informed. Good oil analysis on one car, using one driving profile, with a particular fuel supplier, and other vehicle specific variables will not assure same results on your car. For my truck Amsoil specifically says not to extend oil changes due to fuel dilution. Amsoil is good oil, I use many of their products.
Sent from my Moto G (5) Plus using Tapatalk
My camshaft situation was hypothetical.
Personally during the powertrain warranty period I would simply follow exactly what GM calls out, document it, use exactly the oil they specify along with AC Delco filters.
Would it be worth the potential headache to save a few hundred dollars AT MOST during the warranty period?
To me the answer is no.
After the warranty is up I am all for extending the OCI.
EDIT: The procedure that I do is a time / date stamped picture of the odometer as well as oil life monitor. A receipt showing the oil, filter, date and a photo of the receipt with the items. Again, after the warranty is up then I do things as I see it and don't care much for what the monitor nor GM says.
Given that widespread testing of diesel engines in the EU has revealed about a 99% cheating rate, what makes you think these cars comply with emission standards? I'm waiting for the inevitable class action lawsuit to be filed.
1 - 20 of 27 Posts
