You can go to another dealership if you want, but they'll tell you the same thing. It's noisy.
My ECO has very little wind noise and it's the same body design. One of the biggest sources of wind noise is incomplete or loose door seals on the leading edge of the back doors. Check there - that weather stripping should be secured to the door (mine had to be glued in place) and go from the bottom of the window to the top of the door.If it is anything like previous models then yes, you will have bad wind noise. The wind noise in my 13 LT is annoying but nothing fixed it.
We never did anything with the felt on the window. I will have to check into that. However, I have a slight whistle and I taped up the mirror crack for where it folds and it mostly went away. I was thinking it was that.I just went through this issue on my Cruze hatchback. Took it to my local dealer body shop, they taped the door up and located the issue to be the window felt. They replaced it and I hadn't heard any noises from it since. I had a significant wind noise from my drivers window and I made sure that the dealer knew exactly what I was talking about. I'm also an ASE master tech, so I made sure they understood fully and that I knew it wasn't a normal noise
This might be worth a try:
https://www.youtube.com/watch?v=Egvfsf6cw7Q
I think I'm going to go test drive another 2016/2017 Cruze just to compare, I just need to wait for the weather in my area to clear up. If there's noticeably less wind noise I'm definitely going to go to another dealership. There's a Buick/Cadillac dealership that I sometimes go to for service, but since this is a brand new Chevy, I figured the Chevrolet dealership would be best equipped to handle any issues with the new cars.
My 2013 is also very quiet even at highway speeds with the main source of noise coming from the tires. There is no discernible wind noise.My 2012 is actually very quiet. Even at 75+ mph.
lol No, Nor-Cal, San Joaquin County, Chase Chevrolet and Mataga Buick GMC Cadillac.You must be in the San Fernando Valley from that statement right? talking about Woodland Hills Gmc/Cadillac?
Same, my 2014 LT is extremely quiet, I only hear tire noise even when the wind is blowing me off the highway. Sucks the gen 2 hasn't fared the same.My 2013 is also very quiet even at highway speeds with the main source of noise coming from the tires. There is no discernible wind noise.
