Well, if and when I get hooked on the MiniDSP (likely right after doing my Cruze system), that high pass filter won't be a problem!
That looks like a HUGE box! What's the total volume of that beast?I finally finished the box for the SSA Icon 15".
A little something I learned while building home theater speakers out of MDF is that MDF absorbs moisture like crazy. It's why you need to wear a mask when cutting MDF, and why your hands will dry out and your skin on your knuckles will start looking chapped and cracked over time. It's also why you need to seal all surfaces of MDF before attempting to paint, because the MDF will just keep absorbing. The easiest way to seal MDF is to brush over it with a 50/50 mixture of wood glue and water, and do a light sanding afterward to flatten it out. It's far cheaper and less toxic than fiberglass resin, and achieves the same results. I use it on the baffles I make for people to give them some protection from moisture in the doors. This might also show you why I always upholster or carpet my boxes instead of painting them, lol.I finally finished the box for the
SSA Icon 15". Now just waiting on the sub, in the middle pic the painting isnt done. View attachment 9584 View attachment 9585 View attachment 9586
Between 5.1 and 5.3 cubic feet. From my PM to him:That looks like a HUGE box! What's the total volume of that beast?
That is, assuming he used the specs I recommended and not something else.3.875" (3-7/8") wide x 11" tall, and 31" long. Naturally, you will need to make a bend in order to make the port work.
The port itself will displace around .85-.90 cubic feet, and you need 4 cubic feet for the sub itself, so including the driver displacement and port wall displacement, build the box to a total of 5.1-5.3 cubic feet.
Well, it looks like you carved arches into the bracing that weren't necessary. I doubt the motor is wide enough to need arches that deep. You could have left more material there to add some more strength to the box. It's not a huge deal, but something to do differently next time.what do you mean i cut the circles low in the braces. i cou;ldnt make my mind up how to cut the braces and almost went with a soild divider with the middle cut out leaving two inchs all around the box.
Can you get me some pictures of those speaker locations? What are the dimensions you have to work with, including depth?I was wondering, i want to change out my door speakers and want to know what speakers you recomend, i want it to be clear and smooth blending nice with the icon. Ill get an amp to so your advice and reccommendations are appreaicated. I have 3" speakers in the console, in each door there is a 6X9 spacer filled with a 5 1/4" and a 1" tweeter. In the rear deck i have two 6X9 holes. also do i need to get highs and mids or is there a speaker that does well with both.
Fs: 27.6 Hz | 27.9 Hz |
Re: 0.65 Ohms/coil | 1.27 Ohms/coil |
Qms: 6.56 | 6.45 |
Qes: .52 | .52 |
Qts: .48 | .48 |
Mms: 434g | 424g |
Cms: 0.77mm/N | 0.77mm/N |
Sd: 810cm^2 | 810cm^2 |
Vas: 70.4 l | 70.4 l |
Spl: 86.4dB 1W/1m | 86.5dB 1W/1m |
Bl: 13.7 N/A | 19.1 N/A |
Xmax: 33mm | 33mm |
Rms: 3000W | 3000W |
Sealed box: 2-3.5cuft | 2-3.5 cuft |
Ported box: 3-5cuft | 3-5cuft |
Sub OD: 15.625” | 15.625” |
Cut ID: 14.125” | 14.125” |
Mounting depth: 11.250” | 11.250” |
Displacement: 0.21cuft | 0.21cuft 3.Seal off the trunk, port on drivers side, subwoofer on the passenger side. |
4.Crescendo BC3500D 5.Hip hop, rap, rock, country, decaf 6.I am looking to have at least a good amount of trunk space left, and I am looking for a box design to play the lows extremely well. I noticed that you are a very knowledgeable man with great amount of talent. I am in no hurry to have your feedback, I still need to purchase all of the items I need, so take your time, and sorry to hear about what happened. Thank you. |
Generally speaking, you shouldn't expecting a vented SPL-oriented 15" sub to leave you much trunk space. That's the nature of the beast.1. Fi SP4 15"
2.
Fs: 27.6 Hz | 27.9 Hz Re: 0.65 Ohms/coil | 1.27 Ohms/coil Qms: 6.56 | 6.45 Qes: .52 | .52 Qts: .48 | .48 Mms: 434g | 424g Cms: 0.77mm/N | 0.77mm/N Sd: 810cm^2 | 810cm^2 Vas: 70.4 l | 70.4 l Spl: 86.4dB 1W/1m | 86.5dB 1W/1m Bl: 13.7 N/A | 19.1 N/A Xmax: 33mm | 33mm Rms: 3000W | 3000W Sealed box: 2-3.5cuft | 2-3.5 cuft Ported box: 3-5cuft | 3-5cuft Sub OD: 15.625” | 15.625” Cut ID: 14.125” | 14.125” Mounting depth: 11.250” | 11.250” Displacement: 0.21cuft | 0.21cuft
3.Seal off the trunk, port on drivers side, subwoofer on the passenger side.4.Crescendo BC3500D
Thank you.
