1 - 20 of 34 Posts
I have searched and searched...cant seem to find the info I am looking for.
We have:
2014 Cruze Diesel
Kawasaki KX250 dirt bike
Kawasaki KX100 dirt bike
I want to get a hitch, and small motorcycle trailer to tow our dirt bikes. I see the diesel isn't rated to tow but I also seen that the SRX has the same transmission, which can tow up to 3000 lbs.
Is there a forum agreed "best hitch" ?
This minimal amount of weight should be fine...right?
Maybe we can get a sticky about 2014 specific diesel towing if we get some good info in here.
The engine/transmission can definitely handle it no question.
The suspension of the vehicle and proper cooling/programming of the transmission is the weak link. Look at the small opening of the front grill, it's designed with minimal air flow in mind for greatest fuel economy, not towing up a grade on an 80 degree day.
Also it's annoying that none of the monitors will show transmission temperature.
Do I think a light trailer with those two dirt bikes is too much, absolutely not but caution should be exercised.
Curt makes a Cruze Diesel specific hitch and wiring harness, google it.
I will repeat what the Holden Cruze diesel owners manual quotes about towing: 750kg for a trailer without trailer brakes, or 1200kg for a trailer with brakes fitted. The real engine cooling comes from the opening under the bumper, not through the grille.
OK great. I am looking at 600-700 lbs of towing weight, not much of that is on the toung its self.
I figured it would be the same as some heavy adults with trunk full of stuff.
This is one that I found on eBay. I am assuming its the "gold standard" of the cruze diesel world.
Curt Class 1 Trailer Hitch Wiring Euro Kit w 1 7 8" Ball for Chevrolet Cruze | eBay
Thanks for all the help, can't wait to get these two paired together so we can do some riding up north.
I will be doing the same with my cruze. Waiting for tax season to come around to buy the hitch, harne amd trailer. I don't think it will be a problem for the cruze. I'd probably tow in manual mode so the car isn't down shifting all the time. I traded my truck in for my cruze and I knew about not being able to tow with it but will anyways. The only thing that does worry me is the warranty.
As has been noted, the car has a tow rating in other countries.
You can fairly well assume this is a result of the U.S.A. system allowing lawsuits for just about anything that is caused by lack of common sense.
Using the info provided for the car used in other locations it is clear that a overall trailer weight limit of around a 1000 lbs. with a hitch tongue weight of 150 lbs. or less would fall into a area that would likely be within the capabilities of this vehicle.
Regarding you, at the operators end of things, just be aware of lengthened stopping distance and, if you find the car continually downshifting, say from 6th to 5th, simply select the manual 5th position to keep the trans cool.
Common sense is the order of the day.....I believe it will be just fine.
Also, in Michigan the most elevation gain you'll probably see is a couple hundred feet. Now pulling bikes up a proper mountain, that could be an issue. Or pulling bikes down a proper mountain without trailer brakes.
Where do you ride?
Discussion Starter · #11 ·
That's a really clean pre 2000 kx250..
Thanks, its a 1995 that has went through a total restoration. Gave up 4 strokes and went to 2 stroke :)
The trailer hitchon ebay you posted isn't for the diesel. Curt make a specific diesel hitch
Got ya, its confusing because part of the add says it will fit and part says it will not. Ill have to just call them direct.
Where do you ride?
Hoping to take advantage of the trail system in the upper part of the lower peninsula. I have did several of them but this year we want to try and hit 15-20 different trails. Always make it to Silver Lake once a year too.
If it was simply a case of US lawsuits then there would be no tow ratings on any Cruze.
As of now it is only the Eco models both gas and Diesel. Can't just be auto trans temps since Eco M/Ts aren't rated to tow either.
Rims are different from gas/diesel but they do share the LRR tires, so is it the traction rating of the tires?
Reactions: KpaxFAQ
Well, since we're guessing a bit, maybe the tires but I'd be more inclined to think along the lines of a cooling issue.
Both the ECO and the Diesel have the slightly more restrictive grill opening and each share the lower shutter system.
Bout the only difference that may make them unsuitable for towing through the eyes of the manufacturer.
Thats it from the WAG department at my end.
I have an engine temperature readout on my DIC and the highest I have ever seen is 91C (= 196F), and that was climbing a really steep long hill following a Nissan Patrol diesel belonging to a friend. I don't thing the engine would overheat with a fairly light trailer being towed.
Does the aussie cruze have the active shutters and restricted grill opening? Did they alter the welds of the frame for added weight reduction like the usa eco and diesel?
This is from the 2014 Owner's Manual:
Weight of the Trailer
How heavy can a trailer safely be?
It should never weigh more than
454 kg (1,000 lb). But even that can
be too heavy.
It depends on how the rig is used.
For example, speed, altitude, road
grades, outside temperature, and
how much the vehicle is used to pull
a trailer are all important. It can
depend on any special equipment
on the vehicle, and the amount of
tongue weight the vehicle can carry.
See [FONT=Arial+20][FONT=Arial+20][/FONT][/FONT]Weight of the Trailer Tongue[FONT=Arial+20][FONT=Arial+20][/FONT][/FONT]
[FONT=Arial+20][FONT=Arial+20][/FONT][/FONT]later in this section.
Maximum trailer weight is calculated
assuming only the driver is in the
tow vehicle and it has all the
required trailering equipment. The
weight of additional optional
equipment, passengers, and cargo
in the tow vehicle must be
subtracted from the maximum trailer
weight.
Ask your dealer for trailering
information or advice.
The tongue load (1) of any trailer is
an important weight to measure
because it affects the total gross
weight of the vehicle. The Gross
Vehicle Weight (GVW) includes the
curb weight of the vehicle, any
cargo carried in it, and the people
who will be riding in the vehicle.
If there are a lot of options,
equipment, passengers, or cargo in
the vehicle, it will reduce the tongue
weight the vehicle can carry, which
will also reduce the trailer weight the
vehicle can tow. If towing a trailer,
the tongue load must be added to
the GVW because the vehicle will
be carrying that weight, too. See
Vehicle Load Limits on page 9-9.
Decisions like this make you wonder about GM sometimes.
Release a turbo Diesel that can't tow what a naturally aspirated 1.8L engine can.
Release a car with standard a/c, p/w, p/l,10 air bags but can not be optioned with cruise control, ie 1.8L LS.
Funny the 1.8L isn't deemed capable for cruise control but it can tow more than the Diesel!
I have towed with my cruze, the curt diesel specific hitch is perfect, get it
i have pulled my 1650# camper with this thing and it handled it no problem. I even pulled a grade for 2 miles at 60mph in 4th gear with my foot buried the entire two miles. Car never moved a needle the whole way. Pulled 75mph in 5th on the interstate with no wind you could hardly tell the camper was back there.
I have about 550 miles towing that thing, and it will get more this year
1 - 20 of 34 Posts
