2014 Chevy Cruze 1.4L 128k miles.
On 2/19 I was driving to work when smoke started coming out of the bottom of my car. Exit the freeway and insected the engine (car overheated approximately less than 5 min). Hose from water outlet burst. Took it to the dealer they replaced the following items:
Water Outlet Part #25193922
Hose Part #13251447
Hose Part #55596898
Coupe of days later I started feeling rough idle and misfire while driving Check engine light and traction control disabled light. Drove it to the dealer and was told cylinder 1 was flooded with coolant. Cylinder 3 was semi filled with coolant. As well as PCV line leaking.
Codes P0300 & P1101
Last night I took off the coil and notice coolant inside the spark plug cylinder 1. I dried up the housing and took off the spark plug and did not notice any coolant inside the cylinder. Please see pictures. So far i have not gotten any miss fire I will drive it again and see if the coolant returns into the spark plug area. There is no mixture of oil and coolant. Picture of Spark plug are 1,2,3,4.
If i do have a leak, will it be better to swap the engine or fix head gasket and replace the head? Any suggestion will help thank you in advance.
Hose Part #13251447
Hose Part #55596898
Codes P0300 & P1101
