2012 1LT 1.4T Auto 223,000mi. Recently had the ECU disable the turbo because of sensor failures. Codes pointed to intake tract. Replaced MAF, MAP and IAT sensors and she came back to life. During the diagnostic processes, I broke down and got the code reader because troubleshooting without them is just silly now. A few long trips after replacing all those sensors, I noticed sluggish performance and fuel economy had taken a dip from around 33-34mpg Hwy to 28-30. I hooked up the code reader and watched the data. STFT and LTFT numbers were spot on, but I noticed that the engine was pushing boost even while going down hills. O2 sensor graphing showed the typical sinusoidal waveform during steady load. I've read that the sensor can behave lazily but appear to be functioning normally which can affect economy and performance. I fear that during the few long trips I took with the wastegate being open did damage to the cat. I suspect the fuel system was running more toward the rich side as a precautionary measure to prevent engine damage due to the sensors not functioning properly and this caused the cat to load up. Once engine performance returned, I wonder if the loaded cat got too hot and damaged the honeycomb mesh inside. Cat temps during moderate load across level ground is around 1200-1300ºF which seems a little hot to me. I have new O2 sensors but I am holding off on purchasing a new cat for now as it is a much more pricey part to just replace without knowing for sure. I feel like 223,000 miles out of the original sensors in the intake and exhaust streams was good life. As it stands at this point, I have put 1400 miles on since new intake tract sensors and engine is not throwing any powertrain codes.
