Ive got a 2011 cruze ls and I cant get the tpms system to relearn. I get to the tire pressure screen on the instrument panel but i get no response from the button on the end of the stalk, nor do i get a horn response. any Ideas ?
what are you talking aboot?The tool has to be held exact angle and position.
Straight up and antenna in front of the valve stem in the tire area. About 2 inches.
If it don't work. Try a fresh battery. Works for me. If it still don't work. Time for a new tool.
Is there a difference between 2011 and 2012? Just wondering because my 2012 uses a TPMS relearn tool at each wheel.what are you talking aboot?
2011 doesnt need relearn tool
2012 was first yr you need relearn toolIs there a difference between 2011 and 2012? Just wondering because my 2012 uses a TPMS relearn tool at each wheel.
No but it's easier.what are you talking aboot?
Thanks for clarifying. 😊2012 was first yr you need relearn tool
Talking about letting air out of the tire in clockwise rotation starting from driver front wheel?No but it's easier.
12, 13 don't need it either. According to this very forum.
That very discussion was had on here 5 years ago.
How OLD are your SENSORS inside each Tire ??Ive got a 2011 cruze ls and I cant get the tpms system to relearn. I get to the tire pressure screen on the instrument panel but i get no response from the button on the end of the stalk, nor do i get a horn response. any Ideas ?
what makes you think TS is even using a learn tool?No but it's easier.
How can you possibly think the tool is NOT easier?what makes you think TS is even using a learn tool?
how does a relearn tool make the button on the end of the stalk respond?How can you possibly think the tool is NOT easier?
What am I missing?
Hope this helps... !!Ive got a 2011 cruze ls and I cant get the tpms system to relearn. I get to the tire pressure screen on the instrument panel but i get no response from the button on the end of the stalk, nor do i get a horn response. any Ideas ?
