Soutma
Discussion starter · #1 ·
I am trying to replace the cabin filter and all the videos I have seen have shown the cabin filter exposed right after the glovebox is taken off, however my one is blocked off by another panel. I had to get a 7 mm ratchet to take off the two at the front but it looks like something is holding it on the left hand side which I cannot access.
I would really appreciate the help!
Is this a right hand drive vehicle? Look to the right of the dash. There should be a pop off panel. Under that are probably the bolts you need to remove. The first few pictures in this link show this on a left hand drive vehicle
There may be some info in here:
If you figure this out, please take some pictures and consider writing a How To for us.
How-To: Write a Tutorial
Discussion starter · #4 ·
On a left hand drive, US model, all you have to do is lower the glove box door and release the cabin air filter compartment clips.
My car is right hand drive but if you look in the picture there are those two pieces of plastic infront of it which attach to the whole panel. I had to use a ratchet to take off the bolts (I'm the circled area) but it looks like something else is holding it down and I can't fully take it off.
Discussion starter · #5 ·
This looks great. I'll give it a go later on... Much appreciated.
