1 - 1 of 86 Posts
Hi, i am from Indonesia, i have same problem with you , with my chevrolet trax, i am already try to make modification as you share the wiring, i am use with voltage regulator and 360 ohm 1 watt 1 %,no dtc,but when i am try, the thermostat still not open on the temperature i want i set the voltage 11volt, but if i check with my scanner, thermostat command still not open, what i am wrong? i want to ask, if we give the voltage will open, but how we know if it will open at temperature we set? Thank you
Hi. This schematic didn't worked for me! Check my youtube channel(adaniel69). I've replaced the thermostat core(with a 80°C one) and put a 365 ohm resistor in parallel with the engine temperature sensor after 6 minutes of engine run. You can connect the resistor manually(via a switch) or put a time relay(like i did).
1 - 1 of 86 Posts
