I have a 2014 Eco with low fuel pressure. I replaced the fuel pump and pressure sensor, still have low pressure. When I changed the fuel pressure module the p/n for one in my car is 22872265, the replacement p/n is 22872266 the parts counter said the original is 22872265 and when you replace it it is 22872266. When I install the 2266 the car will not start. Now under the hood the fuse block is missing the fuel pump relay in position 8 and the fuel relay fuse in position 20 and the terminals are not there to install them and the cover and owners manual all say they should be there Called dealer and Chevy owner service and they all say it should be there and could not find a service bulletin or recall where it was retired. Has anyone else have this issue or now the work around?
