Wheel hub/bearing size
1 reading
16K views 12 replies 10 participants last post by  therealhip_1340
#1 ·
I need new rear bearings on my 2014 Cruze LT, I just don't know where to get them/what size. Every place I look has two different options, one for 15"wheels and one for 16"wheels, but my car came with 17"wheels, are these just labeled wrong on the sites? Has anyone replaced their wheel bearings yet, and if so, which ones did you get?
Thanks!
#12 ·
I have the same car and did the same swap. I went through GM. You can use the dealer or the GM parts direct website, enter your VIN and the parts will pop up. I didn’t have much luck on the aftermarket front either.
no, they are simple bolt ups. Bolts are TTY so try and find new ones if you want (good luck), replace with hardware store bolts or reuse them (not particularly recommended, but I did)
