21 - 40 of 47 Posts
May I bump this thread?
I plan on ordering the 3.4 kit this week and install it as soon as I can.
Is it really worth it? ( honestly I have to ask)
Which kit is the best to get?
Do I have to remove the intake manifold to install the plug?
And will this help with the MAF sensor code as well?
My son is driving "my" 2014 LT 1.4, He is in college 90 miles away, I just want this done Right and 1 time! Lol a little nervous about a modification deviating from the manufacturer.
You have to understand, I am an Aircraft Mechanic, if we deviate it's on the news.
Thanks for any answers anybody can provide
Get the newest kit, you won't regret it.
Yes, it is worth it. you could probably save 15 bucks if you sourced all the parts yourself, but it would cost you more in shipping and hours of hunting... so don't bother, just get the kit.
You don't "have to" remove the intake, but I did so I could scrub it out with soap and water, totally de-grease it inside. I wanted to make sure the plug never comes out, ever. I like fixing things once and done... rework totally torques me off. I washed it in the garage slop sink (I assume you already know to remove the throttle body and other parts first, you should only submerge the stripped plastic intake) with plenty of dish soap, then did the plug job while it was out. you may want to get some round "pipe cleaner" type brushes of various sizes if you take it off to wash it like I did. I tend to overkill things though, you may not want to go this far, but the intake really isn't difficult at all to remove. another note: if you remove the intake, you will be removing the tiny little bypass pipe from it. Be very careful removing that from the intake side. The intake barb that it plugs onto is very tiny and fragile. Take your time, it will snap off quite easily if you start yanking on it like a gorilla.
this does't fix any MAF related errors.
This kit basically replaces a poor design that is prone to early malfunction and failure, so just consider it an air road worthiness directive. the "design" is the same as was originally manufactured, just relocating the valves and replacing with more durable ones.
I would also suggest ordering a couple extra check valves (with the kit when you order it) to keep in the glove box. the one I installed on my sons car is going strong a couple of years later, but it is just a plastic check valve, and it will eventually clog or jam up one day. they are cheap enough to just grab them now so in the case you need them later you won't have to go on a treasure hunt.
Also, I suggest replacing the valve cover with a GM original at the same time you do this, or at least check the diaphragm on your existing one and make sure it is working properly. they often get popped when the PCV isn't working right, so there is a chance yours is already blown out. check it.
also make sure to test the check valve for the pipe that clips onto the turbocharger end. I am attaching a photo, the circled part is where the check valve is located. You will be cutting this piece off and re-using it with the kit. when we did ours, this check valve was trashed from running for so long with a malfunctioning PCV system, so I had to amazon-order a new pipe so I could get a good check valve. I'll also include a link to the amazon part I am referring to in the case you need one. The valve is easy to check, simple one-way. air should freely flow one direction and slam shut tight not allowing air to go the other direction.
PCV pipe: GM Genuine Parts 25193343 Positive Crank Ventilation (PCV) Valve Pipe with Bypass Valve Tube
goood luck!
goood luck!
Wow! Great! I appreciate your response, We only had the P0420 code come on twice in 7 months and the code just popped up for the MAF so I have to look at that also. I want to fix it so I don't have to drive to him and fix it.
(Learned my Lesson with son #1 and a 95 s10) I will get the extra check valvas also.
Thank You for the advise!
put mine in a year ago . Going strong…. Is it worth it??? YES !!!! You’re taking a rubber check valve out of a high suction/ vacuum area that is inside the intake manifold. It is not if, but when… ( gm what were you thinking ) and moving it outside the motor. Easy access. Super simple. I did not remove my intake. I recommend getting the tools. The cleaning brush was excellent. Used throttle body cleaner. So much sludge//// attache the plug to the screwdriver and…. Take a couple of trial runs before attaching the plug to the screwdriver, making sure you know where the hole is! feeling for the hole, or you will drop it in … read a few have and no harm…. Plastic chewed up a spited out I guess…also recommend spending the extra 50-60 bucks, and replace the other 1 way valve at the back of the turbo, and the pcv pressure regulator. Again way to go GM… glued to your valve cover… none of this is hard just time consuming… and if you replace the valve cover just search this site for step by step, yes you definitely want a torque wrench and follow the tightening sequence. Kit includes everything hose from the turbo… T’s and great online videos….. now comes my next headache the Cruze 1.4 EVAP canister… with 150k OEM canister valve is not working right/stuck here I go again…. What where they thinking…. Attached to the top side of the tank…watched video partially dropping the tank and getting out was a pain… guesss gm feela if that goes so does the fuel pump…. Dealing with exhaust tubing… fun fun fun
Thank You,
I'm glad there are positve reactions for this mod!
I bought the 3.1 or so kit back when but have not yet installed it. Should I order the latest version, or ask for supplemental parts that may have changed/evolved?
Thanks.
Ask Extreme, he will set you straight.
@XtremeRevolution
I'm another that has suffered the PCV issue. While I would have purchased Andrei's V3.4 kit, I was hamstrung by time and the need for the car ASAP, which was very frustrating in the end. As an aircraft mechanic with car OCD, I have the manuals and usually the time to do my own work.
This next bit is mostly applicable to the Australian market however, it may also be applicable in the US.
If you look at the prices on Cruzekits, you will see that this fix extremely cost effective and an easy solution, thanks to Andrei's efforts.
In Australia, dealerships are unable to just order the manifold and transfer the serviceable components from the old manifold. The intake manifold in Australia is sold complete with a throttle body, fuel rail, injectors and the emissions solenoid valve. The total cost to replace your PCV valve is $2200AUD + labour. :mad:
So my advice is get in early and get one of Andrei's kits!! Even with the cost of shipping downunder and your own time to install the system, you will financially better off. Not to mention the longevity of the kit.
I took a couple of pictures of my old manifold and sectioned the rear side to capture an image of the poorly designed and cheap valve, that just cost me a small fortune.
So for those that come across this article, get on to Cruzekits and read their information. If you have basic hand skills and the time, it may save you an argument about the car repair cost with your wife or partner. (y)
Cheers,
Mark
Cheers,
Mark
Thank You Mark!
I am an Aircraft mechanic as well, and have worked on all of my vehicles for over 40 years(yes, I am getting old!)
I have a 1995 s10, a 2002 Silverado, and my wife's 2020 pathfinder.
The 2014 cruze was mine but I gave it to my youngest son after he complained too much about the S10.
(A/C stopped working).H
I am now swapping in a LS 5.3liter V8. So that will be fun!
Anyway, I have the Kit from cruzekits.com, just waiting for my son to bring the car home for a few days so I can install it.(He us in college 90 miles from us)
I might even but a new intake manifold just for good measure because OCD!
Dorman sells the bare manifold, but I like to get acdelco or OEM parts as much as possible. Rockauto.com is a great place for that.
Thanks for piping in!
Sorry it cost you so much$.
Just curious, how many miles are on the 2014 cruze your putting the kit on?
119k, Last year December we got the p0420 code, I put 2 bottles of Techron in the tank and it stayed off till last month.
My intake manifold was replaced under wry in 2016. The first one cracked.maybe that's why I went so long before having an issue?
Ok Gang, need some help, installing the V3.4+ kit as I am typing this.
As stated in my last post, my intake manifold was replaced some years ago when the car was fairly new. Did GM change the Intake manifold to include a better plug?
I am having trouble removing the old one.
Anybody run into this?
Thank You
Thank You
I believe you may have called me to discuss this, but for anyone reading this in the future, GM didn't change the design on this. You may have difficulty removing it since it hasn't degraded to the point where some of them have yet, but you can quite easily remove it by giving it a whack with the palm of your hand with a flathead screwdriver. People do this quite often on brand new OEM manifolds when they install my kit, and I believe both BNR and Super Cruzes offer ported manifolds with my kit preinstalled that have this already done.
Yes Sir, it was 2 weeks ago. I was rushing to get the kit installed.
I had short window of oppertunity to accomplish the kit install. I had watched your YouTube videos a couple of dozen times and there I was... Second guessing myself in the 11th hour, LOL.long story short,
I left the factory intake "valve" in the intake, did complete the cam cover, and hoses.
I followed my son to the gas station to fill him up before he headed back to college.
While there we checked the Oil level, it was low so he decided to add some from the full 5 qt jug in his trunk, he spills oil everywhere and the exhaust was hot so you know what that does, we try to clean up the Oil as much as we can. He leaves, I head home. He called me 30 minutes later, CEL is on again.
For 2 weeks he keeps clearing the 1101, 0420, and others I can't remember, all related to lean condition and replace cat.
Yesterday he got home, I opened the hood and there was oil all over the place!
After a few minutes of assessment I realized the Oil fill cap was not installed correctly and it spewed oil all over! Kids...
I looked into the intake and the valve/plug was gone... Completed the epoxy repair, topped off the oil, cleaned the engine bay, and now we just test drove it 20 miles with no issues.
Sorry, tried to keep it short. Sucks working on vehicles that only come home once a month, on Non-Home game weekends!
Thank you for answering I will keep everyone updated.
update:
As of today, Saturday 11-9, the car has been driven 276 miles both highway and city driving. No problems at all! The check engine light has not returned! Thank You!
update:
Very glad to hear this all worked out. It's crazy how randomly those check valves fail on people, since you cleaned it up, left it in place, and the next time you checked it it was gone. I'm glad it all worked out well though!
Yes Sir! Working well!
The Oil Usage has stopped, and the Check Engine Light has remained unlit! I bought 10 bottles(12 oz) of Chevron with Techron and my son has used 1 with every fill-up. Hopefully it will clean out the engine enough and keep it running smooth.
Thanks Again!
Thank You
Alright y’all, I’m here to eat crow & admit my Cruze needed the PCV fix kit!
If you look at my past comments, I was certain the fix kit was just a member of the community trying to profit off us…until I noticed my PCV hose was cracked & leaking putrid odours…
It’s only been a day, but the smell has already dissipated to a shell of what it once was (thankfully).
My MIL has turned off & it doesn’t idle anywhere near as rough after coming off the highway.
Thank you Dre - hopefully my Cruze can make it another 200 000km’s because of your fix kit!
Attached is before & after pictures.
21 - 40 of 47 Posts
