361 - 380 of 383 Posts
OK, let’s start!
I had multiple Cruze cars since 2011, unfortunately I can’t say I have/had one free of issues! Talking about the heating and cooling, I saw different & multiple issues reported by people. I did many changes to my cars during the years and I’m going to share with you a few interesting things about the thermostat, specific for 1.4L turbo (ECO). It can be similar issues for other trims, even for Diesel, but the cars I tested & modified are Cruze ECO 2011-2014.
Based on testing 4 cars, here are my observations:
First, the “input data”:
  1. The OE Thermostat on Chevy Cruze ECO (1.4L turbo) from 2011 to 2016, is with a wax thermostatic element that starts opening at 105°C (221°F).
  2. The OE Thermostat is also wired and controlled by ECM. Based on different algorithms and program codes, the thermostat can open at any temperature at any time, if the ECM requires that!
  3. The water temperature display gauge is… a joke! I monitored it for different cars and compared with data from OBD. The dial moves when the temperatures increases until… until 185°F (85°C) only! Then stays there, right before 6 o’clock, no matter how high is the real water temperature. When I tested this, I changed the coolant concentration, adding much more water into the system and let the engine run until the water started boiling. The gauge was at the same position max position, telling me “everything’s ok!
4. The expansion OE tank cap is opening only at 20PSI.
Under all these conditions, the coolant temperatures during normal driving conditions stays around 220°-230°F. I said normal driving conditions because when the engine is overheating, the ECM controls and changes everything. It may open the shutter grille to help cooling down and also it can open the thermostat at any temperatures it “wants”, based on data collection. So, not only that you drive with coolant at high temperature, but also the entire system is at high pressure, since the tank cap opens over 20 PSI. In theory, a higher engine operating temperature helps improving its performances. Well, maintaining a higher temperature for the engine and cooling system requires also better quality system parts. Coolant’s boiling point is way too high under the condition I mentioned so everything is ok until… One small crack into the system will lower the PSI and of course the boiling point of your coolant. Add adding more water into the system and you will lower it even more until the coolant will start boiling time to time, without you notice it I replaced the recovery tank a few times, and many hoses all the time! Many others did the same things on this forum.
Sick of changing parts all year along I decided to change the thermostat and go “old school”. It took me a while until I found something that works but here is what I did. I bought a new thermostat housing 55593035Dorman 902-2080 (GM) that is for Cadillac ELR 2014 Chevy Volt 2011-2014. Do not buy MotoRad, it is a different new model, it will not work! You need the one with the “cage”, see the attachment. The housing is different from the outside, but the internal thermostat is fully compatible with Cruze’s thermostat housing. Push the cage and rotate as in my picture, then take out the spring and “cage”. The thermostat will come out relatively easy. It looks the same as the other one, only the wax inside is different and starts opening at 176°F (80°C). Be careful with the 2 legs, don’t bend them so they can go straight back into the housing.
I’ll not got into details of how to take out the existing thermostat, there are good posts on this forum. Put everything back, and make sure you have enough coolant. Then, old school again, I changed the tank cover with one that is opening at 15 PSI, not 20 PSI (MOTORAD T46 )!
I did this replacement on 6 ECO-s and these cars have between 500 to 3200 miles since. No issues at all! The temperature goes usually up to ~184°F then the thermostat is fully opened so the temperature goes down around 180°F. I didn’t notice any drastic changes to MPG! I have hot air blowing inside the car as I had before the swap.
I did all the changes I mentioned because me and my friends have multiple issues with the cooling system since 2011. If you like the solution and have questions, please let me know. I don’t want to argue with anybody about why GM built the system in the way it is so don’t challenge me! :p
View attachment 254953 View attachment 254961 View attachment 254969
Hey borther can u sell me a thermostat swapped? U might have more lucky finding the parts. Thanks in advance
Sure
do any of you guys with lower temp thermostats see the temp gauge fluctuate when driving at higher speeds? mine does i have the zzp thermostat installed
Out of curiosity I tried the zzp on me and my daughters cruzes. ZZP apparently has 2 sources of them and the were considerably different looking. The one I put in my car is rock steady and great. My daughters fluctuated a bunch and slowly just started opening later and later every time I talked to her. So I switched her back to the 176 thermostat this post is about. My zzp sets almost rock steady at 208.
I'm thinking about doing the lower temp thermostat swap on mine and/or my brother's 2014 eco cruze. Maybe this was mentioned before in the 19 pages (too many to look through) but I noticed on amazon that the motorad t-46 cap was unavailable but there's two acdelco 15 psi options, the RC85 and RC98. Curious if anyone knows if either of those work/fit on the gen1 cruze?
I shall say this only once: You don't need a lower 'Hail, Mary' Cooling System overpressure valve to operate at a lower coolant temp!
The cap is only useful when the coolant overheats significantly, to protect the weakest hose from bursting sooner than later, that's all.
You can source that latter OR mod the current 20PSI cup into a lower setting (as I've done with mine).
OK, let’s start!
Do you know of a way to do this to the 2017 model cruze...I've done this job successfully on a 2012 and it's working flawlessly but the 2017 is all different?
The 2nd gen Cruze already has a lower temperature thermostat.
Are you sure? I thought that but I looked up replacement thermostats on roackauto and they all said 220°?
A lot of posts on this forum say it’s a lower temp. One way to tell for sure is if you monitor the temperature with a OBD reader.
Are you sure you selected 2017 when you checked RockAuto? Here’s what I found. One says 176 and one says 180.
Hey brother u willing to do the swap for me? Willing to pay. Cant find the parts to do it
28290034 and 25200456 are the oem numbers to do this now. Shop around as the dealer can be a bit on the pricy side for them.
My take on the thermostat swap.
I have about 1000 miles on the lower temp thermostat and no problems. It rarely gets above 180F unless sitting in traffic. Highest I have seen it so far was 209F in traffic and about 80 degrees outside.
The only downside for me is that my P0420 code (from my aftermarket cat) comes back after only 5 warm-ups like clockwork. I used to get between 9 & 12 warm-ups before needing to reset it. It’s not a huge deal because I keep my OBD reader plugged in all the time. It’s just a small annoyance.
my 14 Cruze manual stays between 160 and 183. Only downside I have is how long it takes to get heat in the car during the winter. Not having coolant leaks is worth the trade off of lower cabin heat
I did the swap with 2 doorman parts and then realized I had a good part left over from the leftover parts and was thinking of returning it. Then also realized i bet someone already did that and i just replaced a 212 thermostat with another 212 thermostat. And the more this is known about the more that parts are going to be mixed up from coming out off the returns department. Will have to see how it works out.
Sure
Well my ZZP sensor went out last friday and i believe the t stat was stuck open car could not make heat so i went back to OEM because of availability and it cant hurt the car. Needless to say as soon as i put OEM on and filled car back up with coolant...Start it i can hear hissing in the bay it was the pcv on the valve cover i believe it had been bad but for whatever reason with the cooler thermostat it wasnt noticeable but i assume with the oem t stat there is more pressure under the whole system with higher temps so thats just my two cents i ran the zzp for about a year and a half almost two. And no more temp fluctuations when i stay on the pedal for a good pull with new OEM.
For those of you that don't know how to change the guts of the thermostat and are like me and couldn't find anything about how to do it online, here's how you do it. First remove the spring and spring perch from the thermostats. You simply push the perch in and turn it clockwise until it clears the stops in the housing. Then pull the piece with the thermostat valve it's self off. Then hold the housing by the hose nipple and pull the past piece out. There are two pins for the electric part on this piece careful not to bend them. Then swap those pieces then reassemble in reverse order. That's all there is to it. Hope this helps.
I used a large socket to push in on the perch. That made it easier and safer to turn the sharp metal piece.
