hello all, does anyone have the aluminum outlet installed. If so, does the temp sensor work that comes with it work fine or does the GM one need to be swapped in it’s place? Anything I should look out for? Thanks.
MITZONE Upgraded Aluminum Coolant Housing Water Outlet Compatible with 2011-2020 Chevy Cruze Sonic Trax Volt Buick Encore 1.4L Replace 25193922 902-846 https://a.co/d/8mPuf7G
